Just now, Neo0152 said:
I am in the prosses of getting a pc and would like to know is there any thing better (in suits my build better) for motherboards
http://pcpartpicker.com/p/34W9qs
http://pcpartpicker.com/part/gigabyte-motherboard-gah170gaming3
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/585339-motherboard-help/#findComment-7632001
2 minutes ago, Neo0152 said:
could you give me examples
http://pcpartpicker.com/parts/motherboard/#c=112,113,111,117,110&s=30&sort=a8&page=1
but i generally go for asus boards, they have better bios layout and fan xpert software which is pretty handy
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/585339-motherboard-help/#findComment-7632021
this is my first build btw
nice
well if you ask me
this seems like a decent board
http://pcpartpicker.com/part/asus-motherboard-z170e
do you have any preferred colour? going with any theme?
btw i noticed you have high speed ram, its quite unecessary but i guess no harm getting them anyway
https://linustechtips.com/topic/585339-motherboard-help/#findComment-7632039
1 minute ago, Moonzy said:
nice
well if you ask me
yes I was hoping to stay with a black green theme I really want to use the green h440 i just have to wait for the refurbish to restock or what are your suggestions on cases going for black and green
https://linustechtips.com/topic/585339-motherboard-help/#findComment-7632051
Any reason you have a 1250W power supply? Becuase  that is overkill for your build and even a dual 980 ti build.
The UD5 is a solid board, but you could buy a cheaper one and not be lacking many features, and still have a Z170 board in case you want to ever have multiple GPU's or want to use all the PCI lanes, and actual be able to use the high speed ram you bought.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/585339-motherboard-help/#findComment-7632056
i suppose S340 comes with the razer edition too
and there arent any black and green motherboard AFAIK, only black or black+rgb
https://linustechtips.com/topic/585339-motherboard-help/#findComment-7632065
I eventually what to get another 980 ti but problaly need to take that off the list because i dont really need another
https://linustechtips.com/topic/585339-motherboard-help/#findComment-7632067
There is a gigabyte Sniper board, but I think its more equivalent to the Gigabyte gaming 3. http://www.gigabyte.com/products/product-page.aspx?pid=5564#ov
Well a good 850W PSU would be plenty for two GPU's, and if you are think about doing SLI at all I think going with a Z170 board is a good idea. So ignore those who say "just get a h170 board".
https://linustechtips.com/topic/585339-motherboard-help/#findComment-7632076
I am planning to use only one tv at like 1080p at 60 hz i might eventually get a monitor
https://linustechtips.com/topic/585339-motherboard-help/#findComment-7632104
Bro I'm just going to suggest this.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($233.99 @ SuperBiiz)
CPU Cooler: be quiet! Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler
Motherboard: Gigabyte GA-Z170X-UD3 ATX LGA1151 Motherboard  ($132.98 @ Directron)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  (Purchased For $119.99)
Video Card: Zotac GeForce GTX 980 Ti 6GB AMP! Omega Edition Video Card  ($614.58 @ Amazon)
Power Supply: SeaSonic X Series 1250W 80+ Gold Certified Fully-Modular ATX Power Supply  ($179.99 @ SuperBiiz)
Other: Seagate 1TB  (Purchased For $46.00)
Other: SSD  (Purchased For $140.00)
Total: $1467.53
Generated by PCPartPicker 2016-04-21 16:59 EDT-0400
Also you don't need that big of a powersuplly even if you go SLI you will only need 800 watts max.
https://linustechtips.com/topic/585339-motherboard-help/#findComment-7632109
6 minutes ago, Neo0152 said:
I might overclock some
Well with that build you have a CPU that is not unlocked and technically is not overclockable, you need the 6660K in order to do any real overclocking. Also that Motherboard is B150, so  you definitely can't OC with that. With B150 you can't do SLI either and half of your PCI lanes are usable, and the RAM you bought is also never going achieve those listed speeds as it will be locked to 2133MHz.
https://linustechtips.com/topic/585339-motherboard-help/#findComment-7632292
http://pcpartpicker.com/p/zHPfsY
then what board should i use
2 minutes ago, Imabigmac said:
Well with that build you have a CPU that is not unlocked and technically is not overclockable, you need the 6660K in order to do any real overclocking. Also that Motherboard is B150, so  you definitely can't OC with that. With B150 you can't do SLI either and half of your PCI lanes are usable, and the RAM you bought is also never going achieve those listed speeds as it will be locked to 2133MHyh
https://linustechtips.com/topic/585339-motherboard-help/#findComment-7632299
Well for looks I would go with MSI gaming Pro Carbon (mostly black, and has LED's), but for features and price either the Gaming 6 from gigabyte or ASUS-A (but those are red/black and white/black)
http://pcpartpicker.com/p/4Qph6h
https://linustechtips.com/topic/585339-motherboard-help/#findComment-7632371
