Hello, im new here, and my english is poor so sorry for that ;p
i have problem, i have 2 hd 4890 and wanna crossfire them but all drivers i can find, doesnt support this cards anymore. can u help me? where i can find right drivers for crossfire those two. Both working great alone.
I have Win 10x64
Intel Pentium G4400
Z170a g43 Plus
8gb Ram
PSU; Coolermaster GX750w (no adapters for pcie power connectors)
https://linustechtips.com/topic/583799-crossfire-4890-problem/
AMD don't support the original TeraScale cards anymore. As of Catalyst 13.9.
Your best bet is Windows 7.
https://linustechtips.com/topic/583799-crossfire-4890-problem/#findComment-7615973
@harrynowl is correct.
The Radeon HD 4000 series and older, are now under Legacy support -- and Radeon HD 7600 and below, HD 6000, and HD 5000 have been moved to *WIndows 10* Legacy support too.
For your HD 4890's you could try the Windows 8.1 drivers, and see if that works.
http://support.amd.com/en-us/download/desktop/legacy?product=legacy2&os=Windows%208%20-%2064
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/583799-crossfire-4890-problem/#findComment-7616226
I got my HD4870x2s to work with the Legacy driver from W7 in W10 but CCC is broken so I can't enable X-Fire.
But I'm not too bothered cause they're a stop gap until the HD6870s come :P
https://linustechtips.com/topic/583799-crossfire-4890-problem/#findComment-7616261
i saving money for 390, i know this two now are piec of shi*, but i get 2nd for free so i want to crossfire it ;D i also wanna buy i5 6600k, i didnt have money to buy all , but i had to upgreat pc. and now, i dont know what to up first, gpu or cpu, i dont ussualy play new tittles so this setup is fine right now (i was console player for 14 years.)
when im instaling old catalyst some bugs come up but i dont understend anythink
<?xml version="1.0"?>
<?xml-stylesheet type="text/xsl" href="Report.xml.xsl"?>
<monetreport xmlns:dt="urn:schemas-microsoft-com:datatypes">
  <general>
    <cmdline>-UI </cmdline>
    <time>04/18/16 21:25:07</time>
    <action>install</action>
    <download></download>
  </general>
  <dcm>
    <primary>
     <name>AMD Radeon Graphics Processor</name>
     <manufacture>Advanced Micro Devices, Inc.</manufacture>
     <chiptype></chiptype>
     <chipid>0x9460</chipid>
     <vendorid>0x1002</vendorid>
     <ssid>0x2281</ssid>
     <ssvid>0x1787</ssvid>
     <classcode>0x030000</classcode>
     <revisionid>0x00</revisionid>
    </primary>
    <device>
     <name></name>
     <chipid>0xaa30</chipid>
     <ssid>0xaa30</ssid>
     <classcode>0x040300</classcode>
    </device>
    <device>
     <ssid>0xe115</ssid>
     <ssvid>0x174b</ssvid>
    </device>
    <device>
     <name></name>
     <ssid>0xaa30</ssid>
    </device>
  </dcm>
  <exist>
<package>
	<description>Menedżer instalacji AMD</description>
	<result></result>
	<version>9.0.000.4</version>
	<size>20 </size>
</package>
<package>
	<description>AMD APP SDK Runtime</description>
	<result></result>
	<version>10.0.937.2</version>
	<size>90 </size>
</package>
<package>
	<description>AMD Accelerated Video Transcoding</description>
	<result></result>
	<version>12.5.100.30429</version>
	<size>3 </size>
</package>
<package>
	<description>AMD Drag and Drop Transcoding</description>
	<result></result>
	<version>2.00.0000</version>
	<size>1 </size>
</package>
<package>
	<description>AMD Media Foundation Decoders</description>
	<result></result>
	<version>1.0.80430.0002</version>
	<size>1 </size>
</package>
<package>
	<description>Catalyst Control Center</description>
	<result></result>
	<version>2013.0429.2313.39747</version>
	<size>150 </size>
</package>
  </exist>
  <install>
<package>
	<description>AMD Display Driver</description>
	<result>Fail</result>
	<version>8.970.100.7000</version>
	<size>90 </size>
</package>
  </install>
  <uninstall>
  </uninstall>
  <downloaded>
  </downloaded>
  <resource>
    <hwinfo>Hardware information</hwinfo>
    <existpkg>Existing packages</existpkg>
    <pkg2inst>Packages for install</pkg2inst>
    <pkg2uninst>Packages for uninstall</pkg2uninst>
    <otherdev>Other detected devices</otherdev>
    <errmsg>Error messages</errmsg>
    <name>Name</name>
    <manufacture>Manufacturer</manufacture>
    <chiptype>Chip type</chiptype>
    <chipid>Device ID</chipid>
    <otherhw>Other hardware</otherhw>
    <download>Download packages</download>
    <succeed>Success</succeed>
    <fail>Fail</fail>
    <vendorid>Vendor ID</vendorid>
    <classcode>Class Code</classcode>
    <revisionid>Revision ID</revisionid>
    <ssid>Subsystem ID</ssid>
    <ssvid>Subsystem vendor ID</ssvid>
    <header1>Catalyst™ Install Manager</header1>
    <header2>Installation Report</header2>
    <finalstatus>Final Status:</finalstatus>
    <versionofitem>Version of Item:</versionofitem>
    <size>Size:</size>
    <bytes>Mbytes</bytes>
  </resource>
  <error><msg>Driver Install: the specified driver package was not installed for matching devices</msg></error></monetreport>
https://linustechtips.com/topic/583799-crossfire-4890-problem/#findComment-7616448
  • 4 years later...
