16 minutes ago, m2234323 said:
it is hard to decide if I should be ok with the 13inch mac book pro and the game frame rate for game like city skyline like 18 frames a second on low or get a 15 inch or get a gaming laptop or buy a pre made pc or make my own
budget?
https://linustechtips.com/topic/583683-need-help-decide/#findComment-7614802
24 minutes ago, m2234323 said:
about how  much money would a gaming pc  cost to run  on power
I think a gaming system for $ 700 would pull around 250 Watts from the wall under a typical gaming load. If you're paying 15 cents per kW you'd be paying less than 4 cents per hour of gaming in terms of electricity.
https://linustechtips.com/topic/583683-need-help-decide/#findComment-7615299
22 hours ago, m2234323 said:
 how to decide new or used  part or buy a ready bult one from online or eBay
At your budget, all new should be fine, but for better value for money, you can get some parts new and some parts used. Try not to get ready-built ones, they usually aren't that good for the money. Try to build it youself as it'll usually be better than what the custom builders offer you. its easy, just be careful and look at some guides on youtube if your unsure.
https://linustechtips.com/topic/583683-need-help-decide/#findComment-7620140
Here's what you could get for $675.
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($179.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($53.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory  ($27.99 @ Amazon)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($57.08 @ NCIX US)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($45.89 @ OutletPC)
Video Card: PowerColor Radeon R9 380X 4GB PCS+ Myst. Edition Video Card  ($223.98 @ Newegg)
Case: Thermaltake Commander MS-I Epic Edition (Black/Red) ATX Mid Tower Case  ($34.99 @ Micro Center)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($48.99 @ NCIX US)
Total: $672.90
Generated by PCPartPicker 2016-04-19 10:04 EDT-0400
https://linustechtips.com/topic/583683-need-help-decide/#findComment-7620186
10 hours ago, m2234323 said:
for that price, terrible.
how to decide amd vs intell
anything with a budget below $400, amd. above that, intel.
27 minutes ago, m2234323 said:
how to add wifi to the computer where it would go wifi is my owny option
some motherboards have integrated wifi, or you can get a usb/pci-e wireless network card. and try to put all your questions into one comment
https://linustechtips.com/topic/583683-need-help-decide/#findComment-7624759
just get this and build it yourself. its not hard at all, just be careful.
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($43.99 @ Amazon)
Case: Thermaltake Commander MS-I ID ATX Mid Tower Case  ($29.99 @ Newegg)
Wireless Network Adapter: Gigabyte GC-WB867D-I 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter  ($29.89 @ OutletPC)
Total: $695.89
Generated by PCPartPicker 2016-04-20 08:33 EDT-0400
https://linustechtips.com/topic/583683-need-help-decide/#findComment-7624777
  • 1 month later...
