General Question about cabling
Solved by W-L,
6 minutes ago, ddbtkd456 said:How would this be done just curious and what would need to be required to do this?
This would be a easiest way of doing it, but may also require the IP's of the two systems to be configured:
http://windows.microsoft.com/en-ca/windows/connect-two-computers-crossover-cable#1TC=windows-7
In most cases a crossover cable is all that is needed but check to see if the ports on the boards support it autosensing or the option to have a crossover mode, if it does then a regular ethernet cable will work.
