I have 2 questions:
1. I have a Logitech G502 and G710. They are both set to automatic game detection, and I created a specific profile for Minecraft with some macros. As I was selecting the file location of the game so that my peripherals would automatically switch to my Minecraft profile when I open it, I could not find an executable for the game, just the launcher. I selected that, and it does not work. Just to try, I checked whether it would work on the launcher itself, but it didn't. My other profiles work when I launch other programs, so I don't think anything is wrong with Logitech. Any help? If it's just not possible, I will just have to manually switch the profiles which will be really annoying.
2. I attached a quick clip of Minecraft gameplay. That visual anomaly: is that tearing? Just want to make sure as I barely game. I know that tearing happens when your graphics card outputs more frames than your display's maximum refresh rate, and you eliminate it by using V-Sync which may introduce lag, so adaptive refresh rate monitors were made. I tried going to the Nvidia Control Panel and manually selecting V-Sync for Minecraft (MinecraftLauncher.exe) and limiting the maximum framerate to 60 fps, yet nothing changed. Is there any way I could eliminate it besides buying a G-Sync Monitor?
Thanks in advance
Tearing in Minecraft.MOV
https://linustechtips.com/topic/583347-minecraft-questions/
i see no tearing, just loads of motion blur, which i hate
Builds:
https://linustechtips.com/topic/583347-minecraft-questions/#findComment-7611744
After rewatching the clip I attached, you are right. I swear though that I thought I saw it before filiming that clip. What's causing the motion blur and how to eliminate it? Is it the frame rate? I might have had V-Sync on when I recorded the clip which might explain the low framerate.
6 hours ago, elpiop said:
Set the profile for javaw.exe, that is the process that minecraft runs as.
Where can I find it? I searched that in C drive, and there seems to be more than one.
https://linustechtips.com/topic/583347-minecraft-questions/#findComment-7613642
