Can someone link me to a PSU that has a minimum of three, 6+2 connectors? I'm not going to pay over $50, and I want it to be at least 80+ efficiency. The PC that we're upgrading takes up 400W max, so the wattage really doesn't matter. ATX-sized as usual.
*Remember to make sure that the PSU you link has three, 6+2 connectors, a lot of the ones in my price-range only has two, 6+2 connectors.
https://linustechtips.com/topic/582767-need-help-with-picking-psu/
10 minutes ago, Moonzy said:
3x 6+2 connectors takes up to ~450W of power, and thats just on the 12V rail
you might wanna rethink about it `-`
This. While you don't need to spend $150 on a PSU, it'd be wiser to at least step up to the $60 range where you can get something like an EVGA GQ 650.
An EVGA SuperNova NEX 750W would has 3 6+2 pin connectors, at $60 it's not bad.
[Link to Pcpartpicker]
at $50, not I did not see a unit with 3 6 pins
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
