fan What fan do i use? (nzxt s340 white)
Solved by Allshevski,
I would use something balanced like NF-P12's or fans like that. Phanteks fans you have are pretty good.
EDIT: But never airflow, if you can, get some more static pressure as the filter and narrow intake make it a little bit harder to let air through.
Featured Topics
Mesarasi ·
Posted in New Builds and Planning1 -
2
CDR_Xavier ·
Posted in Cooling4 -
1
2
1
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
