It appears that code has been turned into a straight line, so if you do copy+paste you'd need to space it yourself. Annoying.
And when I do replies/posts, my previous reply/post shows up and I have to manually delete it.
"You don't need headphones, all you need is willpower!" ~MicroCenter employee
How to use a WiiMote and Nunchuck as your mouse!
Specs:
Graphics Card: EVGA 750 Ti SC
PSU: Corsair CS450M
RAM: A-Data XPG V1.0 (1x8GB) (Red)
Procrastinator: Intel i5 4690k @ 4.4GHz 1.3V
Case: NZXT Source 210 Elite (Black)
Speakers and Headphones: Monitor Speakers and Phlips SHP9500s
MoBo: MSI Z97 PC MATE
SSD: SanDisk Ultra II (240GB)
Monitor: LG 29UM68-P
Mouse: Mionix Naos 7000
Keyboard: Corsair K70 RGB (2016) (Browns)
Webcam/mic: Logitech C270
https://linustechtips.com/topic/582639-posting-and-code/
I'm not sure what you mean? If I paste code from my IDE into the post, it retains its formatting correctly:
 * Abstract Method: Exists?
 * @param  string $key   Key
 * @return bool
protected function exists( $key )
   return FALSE;
If I paste it into the code dialog, it also works:
	 * @return	bool
		return FALSE;
That's a known issue, but it's working as intended by the forum software developers, and it's very difficult to change without them because it's all hard coded.
HTTP/2 203
https://linustechtips.com/topic/582639-posting-and-code/#findComment-7605145
 * @return bool
   return FALSE;
	 * @return	bool
		return FALSE;
Huh. What I was looking at earlier I had to manually space like 3 scripts.
I guess that issue's out of the way. Thanks.
Specs:
PSU: Corsair CS450M
https://linustechtips.com/topic/582639-posting-and-code/#findComment-7605152
