Having a problem with the TechTips forum?
Go to solution Solved by Bluejay0,
I get the same issue, click on the forums logo and it will fix.
When I go to click on the notifications icon it brings up the small box but is blank and seem to be infinitely loading.
post-15026-0-84413200-1379702457_thumb.p
 (\__/)
(")_(")  GTX 1070 5820K 500GB Samsung EVO SSD 1TB WD Green 16GB of RAM Corsair 540 Air Black EVGA Supernova 750W Gold  Logitech G502 Fiio E10 Wharfedale Diamond 220 Yamaha A-S501 Lian Li Fan Controller NHD-15 KBTalking Keyboard
https://linustechtips.com/topic/58248-having-a-problem-with-the-techtips-forum/
All+my+YES+_e25581da57bb3309c59e3ab1260d
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
Everyone listen i found a sort of fix, click one of the forum areas, eg off topic. Then click the notifications, the url must say https or you will not be able to see the notifications.
Listen if you care.
Yeah the reason why clicking on the forum logo fixes it is cause it adds the https to the link. So to fix this, just edit the bookmark for LTT forums and replace the http with https.
“The value of a college education is not the learning of many facts but the training of the mind to think”
You can view your notifications through my settings by the way ;)
Yours opens the other way due to width constrictions and your name being shorter fyi.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
What? Mine loads the other way.
Mine loads to middle!
post-2255-0-48615400-1379704179_thumb.pn
Going from HTTP site to HTTPS site will most likely fix it (it did for me).
Intel i5 3570k | MSI GTX 670 Power Edition/OC SLI | Asus Sabertooth Z77 | Corsair Vengeance LP 16GB | Fractal Design Newton R2 650W | NZXT Switch 810 SE Gun Metal | BenQ 24" XL2420T 120Hz | Corsair K90  | Logitech G500 / Logtitech Performance MX | Sennheiser PC 360 | Asus Xonar DGX | NVIDIA GeForce 3D Vision 2 Wireless Kit
