Hi,
I just added RAM and replaced cooler from Noctua DH14 to H115i.
My mob is GA-Z87 OC FORCE.
I had 16 GB ram now I have 32GB.
When I try to turn PC on it only turns on for 10 seconds then it turns off for 3 seconds, turns on for 10 seconds then turns off for 3 seconds. I don't know what happened.
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
https://linustechtips.com/topic/582445-problems-with-setup-emergency/
Never mind... RAM was attached incorrectly. Now I don't know if I wrecked my PC....
Main PC:
Case: TT P3
HTPC:
what would you need 32GBs of RAM for?  50 billion chrome tabs?
Builds:
Video rendering.
Main PC:
Case: TT P3
HTPC:
1 minute ago, TheNaitsyrk said:
Video rendering.
does it work now?
Well, now you're reading this, I might as well inspire you with a deep quote
If you fall, I'll be there
             - Floor
so inspiring, so deep, the feels ;-;  THE FEELS ;-;
Newer Build which I'm gonna buy when I haz moneyz
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  (£0.00)
CPU Cooler: be quiet! PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler  (£25.98 @ Novatech)
Motherboard: MSI B85-G43 GAMING ATX LGA1150 Motherboard  (£78.10 @ Amazon UK)
Memory: Kingston HyperX FURY 8GB (2 x 4GB) DDR3-1600 Memory  (£0.00)
Memory: Kingston HyperX FURY 8GB (2 x 4GB) DDR3-1600 Memory  (£29.76 @ Ebuyer)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£0.00)
Video Card: MSI Radeon R9 380 4GB Video Card  (£179.99 @ Amazon UK)
Case: Corsair 780T ATX Full Tower Case  (£149.99 @ Amazon UK)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (£70.97 @ Amazon UK)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For £0.00)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  (£59.00 @ Amazon UK)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  (£24.99 @ Amazon UK)
Keyboard: Corsair K95 RGB Wired Gaming Keyboard  (£184.99 @ Amazon UK)
Total: £803.77
somethings says '£0.00' because I already bought them
probably best remix out there
If I follow you, consider your self lucky, I rarely follow people and when I do it's either because
1) I look up to you
2)I like your picture
3) Or you have an epic ass rig (40 titan x's 9 6700k's clocked at 29GHz that is what I call a epic ass rig, but no one has that soo...)
I inserted it further, and yes it works now, but I'm afraid that I broke something.
Main PC:
Case: TT P3
HTPC:
Did it start?  Did your OS start?  If yes, don't worry, it's fine and go play with your computer.  If no, post more info.
It's posting. Can't go to My PC properties, but it's posting. Recognises RAM, but not the H115i I think.
Main PC:
Case: TT P3
HTPC:
My Pc icon --> Properties. I had overclock etc before. I wanted to check if they're still there, but it's not letting me.
Main PC:
Case: TT P3
HTPC:
