Graphics Card Recommendation
4 minutes ago, OctavianCezar15 said:Hello! Guys
I will be upgrading my graphics card and I would just like to ask if you can you help me recommend a graphics card that can play any game at a constant frame rate of 60 fps or higher at a 1080p display.
Here is my current build:
Processor: Intel Core i7 4790k
Motherboard: Asus H97M-Plus
Memory: 2x 8Gb GSkill DDR3 1600
Graphics Card: Asus GeForce GTX 750
Power Supply: Cooler Master GX-2 550W 80+ Bronze SLI 550W
Monitor: Samsung Simple LED 20” Monitor with High Glossy Black Finish
Casing: Aerocool Xpredator Cube Case
Thanks!
GTX 960 or R9 380x. Or R9 290 if you're okay with used.
R9 390 or 290x if you have the cash. (GTX 970 is eventually going to be limitted by its 3.5 GB of game usable VRAM in later years.)
