3 way SLI- GTX 980 TI for 3D Rendering
Hi guys,
So i recently compiled a new high-end PC mainly for Architecture: 3D modelling, 3D rendering, Animation and eventually gaming.
The basic specs are:
Motherboard: Asus X-99 Deluxe
CPU: Intel i7 5930 K
GPU: Gigabyte GTX 980 TI
RAM: 32 GB
POWER: 850 W
4K display
Now I am aware that there are better components for a workstation out there (Xeon processors, Quadro cards, X-99 WS etc..) but I stand to believe that somewhat similar performance can be achieved with consumer products especially by overclocking. (please correct me if I am insanely wrong).
Having said that I want to boost my GPU for 3D Rendering on software's like 3dsMax (Octane, Vray-RT etc.). I am aware that the 4k display draws a lot of the 6GB VRAM on the GTX 980 TI.
The GTX 980 TI has 2816 CUDA cores (much more than most of the high-end Quadro cards). Therefore, I was thinking on bridging a 3-way SLI with two more GTX 980 TI's. Now, I am aware that this wont boost up the VRAM but only clone the process to the rest of the cards and make use of the CUDA cores available.
My question is how much will a 2 or if necessary 3 way SLI realistically boost the performance? Will (if) rendering time decrease, and how will the rendering workload be distributed to three cards, while running a 4K display simultaneously?
Any advice on this would be much appreciated so please let me know your thoughts, comments!
Thank you in advance, and thank you (LinusTechTips) for the amazingly informative videos you guys post!
Best!
You will probably need more than 850 Watts for 3 way SLI 980 Ti
Anecdotal but for me, I noticed about a 50 to 66% increase in FPS for 2 way SLI for most of my games.
Since rendering is different to gaming, scaling will be good. However your PSU is not powerful enough for 3 cards. I would.recommend a 1200W
Also why not wait for the GTX 1080? It will be slightly cheaper than the 980 Ti as well as being better at rendering due to better FP16 and FP64 as well as being better optimised for the new generation of CUDA.
Pascal will be great as a compute card so it will fit well for your needs
Current Rig:   CPU: AMD 1950X @4Ghz. Cooler: Enermax Liqtech TR4 360. Motherboard:Asus Zenith Extreme. RAM: 8GB Crucial DDR4 3666. GPU: Reference GTX 970  SSD: 250GB Samsung 970 EVO.  HDD: Seagate Barracuda 7200.14 2TB. Case: Phanteks Enthoo Pro. PSU: Corsair RM1000X. OS: Windows 10 Pro UEFI mode  (installed on SSD)
Peripherals:  Display: Acer XB272 1080p 240Hz G Sync Keyboard: Corsair K95 RGB Brown Mouse: Logitech G502 RGB Headhet: Roccat XTD 5.1 analogue
Daily Devices:Sony Xperia XZ1 Compact and 128GB iPad Pro
Wait for Pascal. 3 new cards rumored to be releasing soon (May/June). Has DP compute and better performance.
CPU: Intel Core i7 7820X Cooling: Corsair Hydro Series H110i GTX Mobo: MSI X299 Gaming Pro Carbon AC RAM: Corsair Vengeance LPX DDR4 (3000MHz/16GB 2x8) SSD: 2x Samsung 850 Evo (250/250GB) + Samsung 850 Pro (512GB) GPU: NVidia GeForce GTX 1080 Ti FE (W/ EVGA Hybrid Kit) Case: Corsair Graphite Series 760T (Black) PSU: SeaSonic Platinum Series (860W) Monitor: Acer Predator XB241YU (165Hz / G-Sync) Fan Controller: NZXT Sentry Mix 2 Case Fans: Intake - 2x Noctua NF-A14 iPPC-3000 PWM / Radiator - 2x Noctua NF-A14 iPPC-3000 PWM / Rear Exhaust - 1x Noctua NF-F12 iPPC-3000 PWM
It will be three times the performance for sure: the way I set up multiple gpus for rendering animations is to let each gpu render individual pictures each and create placeholders so that the other gpus know which frames are at the moment rendered. for single pictures it will be a bit less than three times
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
