OK so i posted about buying a Gigabyte 980ti XTreme gaming to replace my Titan X i just sent back to NVIDIA. Now, i'm in the phase of buying a new card.
Since i do not have any graphics cards, i'm using my old EVGA 970 SC in my PC. But now i'm hesitating on the 980ti. I red that 970 can have the same power of a 980ti.
Should i go with my choice of 980ti or 970 sli? Or even 980 sli? (I have a 1500$ CAD budget)
I don't want any ''wait for pascal''.
Thank you
https://linustechtips.com/topic/581372-help-me-to-chose-gpu/
what about fury x?
And it's better to stick to a single card, with SLI/crossfire performance being quite horrible in some titles it's not worth it.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/581372-help-me-to-chose-gpu/#findComment-7592246
Thank you
 Are you doing 4k? Stupid question but...
WAIT FOR PASCAL...jk
https://linustechtips.com/topic/581372-help-me-to-chose-gpu/#findComment-7592249
1 minute ago, samcool55 said:
what about fury x?
I know it's better to stick with a single GPU' but i wanted some opinions
https://linustechtips.com/topic/581372-help-me-to-chose-gpu/#findComment-7592257
1 minute ago, Fourmi Kill3r said:
You... you... you are funny ;P
Nvidia and AMD are like 4 weeks away from massive releases. Now is a stupid time to buy a GPU.
I also echo @Sat1600 's question, which is what exactly are you trying to do that your 970 is struggling with?
https://linustechtips.com/topic/581372-help-me-to-chose-gpu/#findComment-7592258
Play on ultra, i can ''only'' do really high
And i clearly said i don't wanna hear about new gpus
https://linustechtips.com/topic/581372-help-me-to-chose-gpu/#findComment-7592266
Just now, Fourmi Kill3r said:
I want to stay with NVIDIA
Then 980ti is your best option. Other options won't really make much sense.
https://linustechtips.com/topic/581372-help-me-to-chose-gpu/#findComment-7592271
2 minutes ago, othertomperson said:
A 970 should be plenty for that.
I want to go on ultra settings, can ''only'' do high settings with that
Since i'm a big player of Rainbow Six Siege, i want to do ultra mainly on that game, i can only put it a high settings
Edited by Fourmi Kill3r
https://linustechtips.com/topic/581372-help-me-to-chose-gpu/#findComment-7592283
And
13 minutes ago, Fourmi Kill3r said:
I don't want any "wait for pascal"
And
And you want something better than the 970 that you have I guess that leaves only the 980 ti
https://linustechtips.com/topic/581372-help-me-to-chose-gpu/#findComment-7592289
Like I said, a GTX 970 should be plenty for that. Are you sure the GPU is the problem? Worth looking at before you drop £500 on trying to solve it.
https://linustechtips.com/topic/581372-help-me-to-chose-gpu/#findComment-7592435
These are the the exact settings i have.. I want to do msaa and go on ultra... There is no msaa or ultra in this vid
https://linustechtips.com/topic/581372-help-me-to-chose-gpu/#findComment-7592967
...so what you're saying is that you want to spend £500 on a GPU that will enable you to load half of the pixels of your display four, eight or sixteen times.
MSAA is ridiculously demanding, for little real benefit. If jaggies are bothering you try FXAA or something. Don't spend such an extreme amount of money just because one of the most demanding forms of Antialiasing causes your gpu to not run at 120 fps any more.
https://linustechtips.com/topic/581372-help-me-to-chose-gpu/#findComment-7593025
