Hello guys, I'm new here..so I want to buy these components..
Motherboard: Asus M5A78L-M/USB3
CPU: AMD FX-6300
GPU: Asus Strix 960 4gb version
RAM: 8gb DDR3, probably i will upgrade to 16gb, later
HDD: Seagate Barracuda 7200 1TB
PSU: Cooler Master, B700, 700W
Case: Zalman ZM T1- PLus
Are those components compatible?
Thanks for your time!
https://linustechtips.com/topic/581322-my-first-gaming-pc-build/
You can drop in GPU. Case doesn't mattet just choose one you like and almost the same it is with motherboard. There more MOBOs, just make sure it has got right socket. Then choose different PSU, I personally like http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html. It is still useful whem choosing PSU.
https://linustechtips.com/topic/581322-my-first-gaming-pc-build/#findComment-7591933
