PSU is a not to good but decent power supply. i say decent because it wont blow up like coolmax psus would. go single channel 8gb so you can upgrade to 16gb easily later on. if your getting a 980ti later on might as well get an i5 6600k and a z170 motherboard
"Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning." -Albert Einstein
https://linustechtips.com/topic/581131-1000-cad-build/#findComment-7589495
I thought even a i5-2400 will not bottleneck a 980?
https://linustechtips.com/topic/581131-1000-cad-build/#findComment-7589499
6 minutes ago, micko12400 said:
try to get anther HDD to store all your work and maybe if you can squeeze a little more $$ try and get the I5 6600K
if not its a good build might need better cooling aswell
thanks, but if I am not plan overclocking do I still need a better cooling?
https://linustechtips.com/topic/581131-1000-cad-build/#findComment-7589510
