I been trying to build a gaming pc and I'm new into these kinda things, never done it before by myself alone. I'm really confused and need some suggestions about power supply. So these are my specs
Case- thermaltake versa N21
Gpu- msi gtx 970
Motherboard- msi gaming 5
Processor- i5 4690k
Ram- 16 gb ddr3 1600
Kingston 120gb ssd
Wd hard-drive 2tb
Asus dvd drive
Probably gonna have 2 more fans
Cooler Master hyper 212 evo heat sink
The usage probably gonna be over 6 hours.
i need help to choose which power supply will be better for Me.
https://linustechtips.com/topic/580969-help-with-power-supply/
What's your budget and use of the system? Which currency and country?
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/580969-help-with-power-supply/#findComment-7588041
1 minute ago, Nisc-kun said:
I only bought case gpu and motherboard, by next week I'm gonna have all the other parts
Why not get the i5 6600K, price differences between skylake and haswell are almost gone now in the US.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/580969-help-with-power-supply/#findComment-7588057
And if the Kingston SSD is a V300, look for another one since this one had its NAND replaced and is significantly slower now:
http://www.anandtech.com/show/7763/an-update-to-kingston-ssdnow-v300-a-switch-to-slower-micron-nand
https://linustechtips.com/topic/580969-help-with-power-supply/#findComment-7588063
1 hour ago, Nisc-kun said:
I5 6600k is not supported by gaming 5. Thts what pcpartpicker says I think.
Then get a motherboard that does support it. Haswell is in older platform while Skylake is newer, thus the CPU doesn't actually fit in the older socket of a Gaming 5. On PCPP, just delete the Gaming 5 from your list as well as any RAM, then choose a CPU.
Anyways, the EVGA B2 750W has way more wattage than you need and should be in that price range.
https://linustechtips.com/topic/580969-help-with-power-supply/#findComment-7588432
