Watercooling isn't something you should cheap out on. Do it right or don't do it at all.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/580469-cheap-water-cooling/#findComment-7583187
3 minutes ago, Tlawl said:
Hey, I am a university student and don't have a lot of money but I have been able to price out all my water cooling parts for a custom loop for like 140$ canadian are there any big problem with budget pumps and stuff. I mostly want to tinker with the stuff
don't cheap out on liquid cooling, you are putting super conductive materials near water, do not cheap out.
I'm going to say it again:
DO NOT CHEAP OUT ON CUSTOM LOOP
Now, an AIO CPU cooler for $140 CAD is easy, you can probably get a Corsair H100i GTX
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/580469-cheap-water-cooling/#findComment-7583199
I agree with Deadeye. Either you spend enough to get premium parts or you dont water cool.
https://linustechtips.com/topic/580469-cheap-water-cooling/#findComment-7583205
I'll bite.
Xspc makes the least expensive parts
If you really want to cheap out, at least use expensive parts within the vicinity of your motherboard and cpu.
Get an xspc raystorm (70 dollars)
2x 3/8-5/8 compression fittings (15 dollars)
And about 2m of tubing
Connect 1m of tubing to each port on your cpu cooler, run the tubes outside the case a safe distance.  The go ahead and connect a fishtank pump, water hose and the rest of your parts that you bought at home depot.
Use a bucket as resevoir for best results.  No need for radiator.  Just replace the water occasionally or toss some ice in.
https://linustechtips.com/topic/580469-cheap-water-cooling/#findComment-7584020
You might wanna look into phobja products. I am using a tube res (looks really good), a pump and a CPU cooler from them and they work really really well. Might not have the chrome high blick factor of other companies but they work really well.
http://www.aquatuning.de/AtsdCartSave/load/key/f43e52d0e7c2c665767d435d98959ba0 for example. But an AIO cooler will still be cheaper (but less cool ^^)
https://linustechtips.com/topic/580469-cheap-water-cooling/#findComment-7585009
