Hi guys,
So i've built two PC's before, this buget gaming pc build is for a friend.
After i build everything into the case and i connected it to a monitor it wont post, the leds will turn on and all the fans will go spinning (Case&Processor cooler). Yet it wont post.
No signal on the monitor is the message that displays.
I've read something about BIOS updates that might be needed but i dont know if this is indeed needed and if so how to do it.
Thanks for the help!
Parts:
Motherboard: ASrock FM2A55 Pro+
Processor: AMD Athlon x4 860K Boxed
Ram:D DR3 Crucial ballistix 2x 4gb (8gb total) at 1600mhz
GPU: GTX 750TI Superclocked
Intern Storage: Seagate Desktop HDD 1TB
Power Supply: Seasonic M12II Bronze Evo 520W
Parts, (Motherboard not on site for some reason)
http://pcpartpicker.com/p/LRtFwP
https://linustechtips.com/topic/580224-new-build-wont-post-need-help/
13 minutes ago, chiwas said:
Looks like you'll have to update bios if MBO is older then CPU.
"Some AMD A55 chipset motherboards may need a BIOS update prior to using Kaveri CPUs."
i've seen, how do i update the bios without it posting though?
Check all cables, and I mean ALL CABLES!!
PC Specs   - Black and White Build
    Intel Core i5 4690k MSI Z97S Krait LGA 1150
    Crucial Ballistix Sport 1x8GB 1600MHZ
    Sapphire Radeon R9 270 (Will be upgrading this soon)
    EVGA 500W PSU
    Phanteks Enthoo Pro - White
