what temps should I be getting under 100% load??
my ambient is about 18c, it has push pull (nf a12 push, stovk pull)
My rig: r7 1700 @ 3.9/1.35v, 16gb ddr4 3200, assorted rando SSDs, hx 1050, vega 64 1650/1025
MY $75 BUILD https://linustechtips.com/main/topic/576889-the-75-build-log/#comment-7547280
https://linustechtips.com/topic/580035-i3-4170-t4-temps/
80*C-ish max
https://linustechtips.com/topic/580035-i3-4170-t4-temps/#findComment-7578977
1 minute ago, Seminole said:
Since it's a low TDP processor it should be under 45C
The stock cooler is not going to be keeping it that low :D
https://linustechtips.com/topic/580035-i3-4170-t4-temps/#findComment-7578983
im getting mid to high 50's... that is why im confused. im using cooler master high performance thermal compund as well
https://linustechtips.com/topic/580035-i3-4170-t4-temps/#findComment-7578985
I thought he was talking about the 4170T?
That cooler has no copper - it's the smallest stock cooler a modern intel CPU has ever seen :D
That's perfectly fine. If it goes above 80*C then you should be worried
https://linustechtips.com/topic/580035-i3-4170-t4-temps/#findComment-7578989
That's fine that's not bad.
I know but I feel it should be lower. I have seen it in the low 60s
https://linustechtips.com/topic/580035-i3-4170-t4-temps/#findComment-7578998
That's average. You could get a better cooler though if it's in your budget.
welll. its not like I need better. but I just fell like, well yeah.... its not a cheap cooler and I would have thought it would do better
https://linustechtips.com/topic/580035-i3-4170-t4-temps/#findComment-7579014
What cooler are you using?
https://linustechtips.com/topic/580035-i3-4170-t4-temps/#findComment-7579033
t4. push pull fans 100%
https://linustechtips.com/topic/580035-i3-4170-t4-temps/#findComment-7579046
Reseat it - probably not mounted well or too much/too little thermal paste
https://linustechtips.com/topic/580035-i3-4170-t4-temps/#findComment-7579047
done multiple times. is to much thermal paste a thing?
https://linustechtips.com/topic/580035-i3-4170-t4-temps/#findComment-7579063
yes - a small grain of rice worth of TIM - anymore than that and it can cause issues
https://linustechtips.com/topic/580035-i3-4170-t4-temps/#findComment-7579066
will reseat. I put heaps on lol
https://linustechtips.com/topic/580035-i3-4170-t4-temps/#findComment-7579068
re-seated it and tightened everything ran a stress test 100% load 61c (but averaging 58) csgo, 54c at 90% cpu. im happy now. thanks for the help
https://linustechtips.com/topic/580035-i3-4170-t4-temps/#findComment-7579222
EDIT: I was mistaken... I have no idea what t4 is though lol
no... a hyper t4
https://linustechtips.com/topic/580035-i3-4170-t4-temps/#findComment-7579262
CM T4 =/= Intel stock...
Your temps are normal for the cooler and CPU. No need to worry. I would have guessed 60-65C max temps.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/580035-i3-4170-t4-temps/#findComment-7579441
