exactly at 50%?
make sure your PC is on high performance power mode and that there is no CPU limit in premier settings
What video codec are you using it? That could be part of your issue.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
21 minutes ago, xxMega11xx said:
How do you change the limit in premier
idk
just look around int he settings and see if you see any option
if your CPU isnt stuck exactly at 50% then try rendering in a different codec
