GTX 950 clock problem
Go to solution Solved by Lord_Karango17,
If you have already restarted and its still doing the same thing, do a clean install of the newest nvidia drivers.
My gpu sometimes dosent go over 540mhz after a driver crash until I reinstall the drivers
Hey guys I have a problem with my 950, yesterday my average fps drop on every game and I could work out why, so I used MSI afterburner and it turns out that whatever settings is set, my GPU core clock doesn't go higher than 405Mhz under load and the memory clock is at 810 Mhz, the rest is behaving normally. So does anyone knows why ? Btw it's a GTX 950-2G from ASUS.
https://linustechtips.com/topic/579672-gtx-950-clock-problem/
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/579672-gtx-950-clock-problem/#findComment-7575454
basically this, except get the 362.xx or 361.xx drivers, the 364.xx drivers are buggy `-`
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/579672-gtx-950-clock-problem/#findComment-7575575
