Just now, cdsboy2000 said:
http://www.amazon.co.uk/dp/B00C2Q525S  ?
First one I found on amazon. They're really cheap, and full RGB isn't much more expensive.
See any cheap RGB'S ones then?
I like these my only problem(Not really a problem) are those naked wires
http://www.newegg.com/Product/Product.aspx?Item=N82E16811980001
the prices are so weird, they should be 17.99 USD
Theses from Addoncustoms are pretty good for single color LED's and UK based:
http://addoncustoms.com/store/product/35-red-led-strip-5050-tri-chip/
EDIT: Also plz refer back to thread instead of making a bunch of the same one.
-Moved to Modding Section-
I have the s340(mid tower)
How long do you think is enough{LED STRIP]? 1 30cm?
Plastic or Paracord?
How long do you thing the power cord should be?
3pin or Molex
Please help
3pin or Molex
Please help
In general two 30 cm strips either one on each side or one along the top and bottom are best to evenly light the components. In general the other details like length of power cord and connector type and sleeve depends on what you want and need to hook things up. I would say 30-50cm for a power cord are good, 3 pin is my personal preference as long as you have a 12V 3 pin connection and PET sleeve.
so will the normal 3pin fan connectors on my mobo work? and whats PET sleeve?
Yes the 3 pins can be used on fan headers on the motherboard but if you want just to direct power them molex would be simplest, PET is plastic or Polyethylene sleeve, that is mainly up to what you like compared to paracord.
If you like I did a review on them previously here which went over a lot of details.
Thanks dude!! big help!!
1 hour ago, ppppppp said:
Anyone know where i can find some decent, relativel cheap Red LED's(Non-RGB) for my s340 case. UK stores preferably
I'd highly recommend just plain white LEDs. Red LEDs will literally make everything look red.
2 hours ago, ppppppp said:
What about Red LED fans?
Still make everything red. Just build a red system and let it shine with white lights.
Nzxt has a really nice led set that comes with cable managing and an expansion slot card with controls for brightness and on and off. They're high quality and around $12 USD. I used them for my s340 and the smaller ones fit perfectly around the edge.
My GTX 970 carries me to global.
