hi guys please i need your help im a first time at upgrade GPU my self...i alrady upgrade my PSU to V750 coolermaster....and im using MSI n560 gtx ti hawk and im upgrading to MSI r9 390 8gb so after i upgrade GPU and i conneted HDMI cable to the moniter and i start the PC at first i try and it keep restart back to back over and over again than i try this in youtube thay say try removeing ram 1 by 1 the first slot i remove than its stop restarting over and over again...but now i dont hear any boot sound and no display on the moniter....but after i remove the GPU and use my old GPU its boot up fine go to windows 7 no problem...but when i try again intalling the new GPU that happen....can any1 help me out?
https://linustechtips.com/topic/578697-hello-please-help/
did you connect the pci-power to the card? did you connect the other end to the psu? `-` (you have to connect ALL the pci power plugs)
if you did the correct connection and its still not powering up, then it might be dead on arrival, check whether it works on other systems
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/578697-hello-please-help/#findComment-7565781
4 minutes ago, eddy22m said:
If you want people to notice your reply, quote or mention them
how to do that?
little arrow on the bottom of their post, you can also quote multiple people in one post by clicking on the + on the bottom as wellquoteing.PNG
You know how it is, the cow goes "moo", the dog goes "woof" and the gamer goes "The PvP is unbalanced."
Personal Computer: CPU: i7-4790 Mobo: Asrock Z97 Extreme6 Graphics Card: MSI R9-380  Memory: 16GB (8GB x2) G. Skill Sniper Gaming Series PSU: Apevia Warlock 750W Case: NZXT Phantom 410 Series Storage: 240GB SSD (OS) 3TB HDD (data and such) 500 GB SSD (Movies and Large Data Transfers (I'm constantly moving this one around to other computers))
https://linustechtips.com/topic/578697-hello-please-help/#findComment-7565843
did you scratch a part of your motherboard while installing?
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/578697-hello-please-help/#findComment-7566432
Ummm....is your monitor plugged into your graphics card and not the motherboard?
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/578697-hello-please-help/#findComment-7567766
ok this is what i think whats happened
1 the motherboard isnt detecting the gpu
2 the gpu isnt sending a display signal to the hdmi
3 gpu doa
1 i would try using a dvi cable between gpu and monitor
2 plug the cable between the motherboard video out to the monitor
https://linustechtips.com/topic/578697-hello-please-help/#findComment-7569606
i did it i take it to the pc shop and thay say i have an old mobo and never been update for 5 or 6 years lol,,, so need to flash bios it did not cos much but thanks guys for the help...now its works...new problem now is i dont know what driver softwere to use with this MSI r9 390...do i need to install all from the CD they included?or is ther any web side that you guys recemmanded for me?
https://linustechtips.com/topic/578697-hello-please-help/#findComment-7569942
