Air cooler choice!
Go to solution Solved by Aytex,
go for the shadow rock
Hi all!
So recently, maybe yesterday or the day before I posted a topic about noctua coolers. Well it turned out that I had to spend some money on other things and now I don't have money for such an expensive cooler!
My current choices are either a hyper 212x or a shadow rock slim cooler from be quiet! they are very similarly prices here in Hungary. I know people always recommend the 212 evo, or the 212x as I don't see many differences. But the shadow rock slim looks soo much better in my opinion. I'm just curious if there is any performance gains with either. i will run a i7 3770 none k so the overclocking does not matter. But I hate how loud and ugly the stock cooler is.
Thanks for your input!!
Intel core I5 4460, Gigabyte H97M-HD3, Gigabyte gtx 760, 8 GB corsair value ram, Thermaltake core v21, Thermaltake Smart 630W PSU
Alcatel OneTouch D5... IT WORKS!!
http://pcpartpicker.com/p/BxMjTW
https://linustechtips.com/topic/578587-air-cooler-choice/
Just now, l_zheng101 said:
A Dark Pro 3 or anything from Noctua will work really well.
As I said I won't have that kind of money. having around 35 USd for a cooler
https://linustechtips.com/topic/578587-air-cooler-choice/#findComment-7564649
Shit sorry. Then by far your best choice is the Shadow Rock Slim.
Okay thanks!! I'll order it in an hour. So untill than I won't make this answered :D haha
https://linustechtips.com/topic/578587-air-cooler-choice/#findComment-7564664
15 minutes ago, Abel225 said:
Hi all!
shadow rock
https://linustechtips.com/topic/578587-air-cooler-choice/#findComment-7564691
For the future if you aren't overclocking almost any cooler should give you acceptable temps, you could even do a passive cooling heatsink if your case has good airflow
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/578587-air-cooler-choice/#findComment-7571323
Well I already ordered the shadow rock slim. And my current case is an old asus case that has no fans. So I do need a cpu cooler. I just want to have a quite system.
https://linustechtips.com/topic/578587-air-cooler-choice/#findComment-7573813
On 4/8/2016 at 9:04 PM, Abel225 said:
Hi all!
http://www.hitechlegion.com/reviews/cooling/heatsinks/40044-bequiet-shadow-rock-slim-cpu-cooler-review?showall=&start=2
http://www.hitechlegion.com/reviews/cooling/heatsinks/13336-cm-hyper-212-evo-cpu-cooler-review?showall=&start=5
This what i could find.
i cant say much but for my G3258 Replacing my Stock Cooler with a 212X it really did wonders, cause in my country i could only find a the near value per $ are from Cooler Master.
GAMING RIG
i5 4590 / 16GB / RX 480 8GB
https://linustechtips.com/topic/578587-air-cooler-choice/#findComment-7574973
I see. I already ordered the shadow rock slim. It looks better and I'm pretty sure it will do wonders :D
https://linustechtips.com/topic/578587-air-cooler-choice/#findComment-7575718
