Just now, Saif-_-Help said:
i am buylding new pc and my budget is 1200$usd wish one is batter/
i7 6700k/5820 and gtx 980/fury nonx
i5 6600k and gtx 980ti/furyx/295x2 if aviLbul
or build that u recemand in this price point!!!
+my main use is gaming and editing.
https://linustechtips.com/topic/578526-chosing-part-help/#findComment-7563953
i7 for sure.
i5 can handle editing too its just deciding between cutting rendering time or cutting gpu performance.
You can check how long it takes for each CPU to tender sometnmhing on youtube, look for "i5 vs i7 editing/rendering test"
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/578526-chosing-part-help/#findComment-7563975
Just now, Thony said:
i7 for sure.
i5 can handle editing too its just if the time difference matters to you too much or not.
You can check that on youtube, look for "i5 vs i7 editing/rendering test"
is the gtx 980ti a big diffrent in preformance over gtx 980/fury
https://linustechtips.com/topic/578526-chosing-part-help/#findComment-7563979
Depends on your resolution. For 1080p the 980ti is slight overkill. For 1440p u do want 980ti.
Not sure what your monitor set-up is. When u edit something the 1440p is better for extra height so u can see more tracks on your timeline.
https://linustechtips.com/topic/578526-chosing-part-help/#findComment-7563982
3 1080p 24in monittor 980 or ti
If u plan on doing surround then 980ti.
https://linustechtips.com/topic/578526-chosing-part-help/#findComment-7563988
gaming + editing as a hobby = i5 6600k + 980Ti
you will get the maximum performance in games
but you will be slightly slower in editing stuffs, but you can use gpu acceleration, depending on what software you use
gaming + editing professionally = i7 5820k + 980
will perform decent in games with great editing times
i would recommend an i7 6700k + 980Ti, its the most balanced build
with ~1200$...
i cant even fit an i5 6600k with a 980 ti lol
here's my proposed build
PCPartPicker part list: http://pcpartpicker.com/p/rd3j8d
Price breakdown by merchant: http://pcpartpicker.com/p/rd3j8d/by_merchant/
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($239.99 @ SuperBiiz)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($69.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR3-1866 Memory  ($59.99 @ Amazon)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  ($68.75 @ OutletPC)
Storage: Western Digital Blue 2TB 3.5" 5400RPM Internal Hard Drive  ($74.74 @ SuperBiiz)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card  ($653.98 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($49.99 @ Micro Center)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($83.99 @ SuperBiiz)
Total: $1301.42
Generated by PCPartPicker 2016-04-08 05:51 EDT-0400
slightly overbudget to squeeze in an xeon (performs like an i7) with a 980 Ti
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/578526-chosing-part-help/#findComment-7563989
with ~1200$...
  Hide contents
Total: $1301.42
ican fit it becuse i have hardrive and ssd laying arround
https://linustechtips.com/topic/578526-chosing-part-help/#findComment-7563994
Just now, Josephdalepi said:
actually, not neccessary
i use the same monitor configuration in surround, plus 4 extra monitors, and i can get ultra off most games with a 970
on a related note, evga rma is amazing, get their cards
i fell like this is the best build|
i5 6600k
asrock z170 pro4
16 gb g skill 16 gb ram
120 gb ssd{i have it all redy}
1 tb hdd{same}
212 evo
msi gtx 980ti{becuse its only 599}
PHANTEK PRO M CASE
evga 650 g2 PSu
https://linustechtips.com/topic/578526-chosing-part-help/#findComment-7564011
i5 6600k
asrock z170 pro4
1 tb hdd{same}
212 evo
PHANTEK PRO M CASE
evga 650 g2 PSu
personally, id get an asus board, but thats just fine
https://linustechtips.com/topic/578526-chosing-part-help/#findComment-7564017
1 minute ago, Saif-_-Help said:
asrock becuse its the cheabest good locking mobo
i guess if orange is your flavour
id probably go a bit more expensive for the a170-k or -a
thats mostly personal preference though
i have never seen anything as easy to overclock as my current z97-a
https://linustechtips.com/topic/578526-chosing-part-help/#findComment-7564033
i will lock for it
https://linustechtips.com/topic/578526-chosing-part-help/#findComment-7564044
Motherboard: Gigabyte GA-H97-HD3 ATX LGA1150 Motherboard  ($99.89 @ OutletPC)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($65.89 @ OutletPC)
Video Card: EVGA GeForce GTX 980 Ti 6GB FTW ACX 2.0+ Video Card  ($619.99 @ NCIX US)
Total: $1288.48
Generated by PCPartPicker 2016-04-08 06:11 EDT-0400
? Btw I haven't read any of the thread.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/578526-chosing-part-help/#findComment-7564056
Total: $1288.48
i feel like the i5 is batter and i have ssd and hdd all radey!
https://linustechtips.com/topic/578526-chosing-part-help/#findComment-7564062
