Help
Solved by Ramidon,
I agree with IsaacDaGrazin, but with that aside. If I was in your position I would recommend just going to you local BestBuy or a different pre-built PC Supplier. If that option is not available for you I have heard good things about CyperPower and iBuypower for ordering a pre built gaming PC. You can refer to the Riot Games Forum Post (which I will link below). This will the recommended requirements needed to play the game. Compare this to any or the pre-built PCs. I’m sure with a couple of hours and research and consulting your budget, you will be able to find the right PC for you.
Link to Riot Games Forum - https://support.riotgames.com/hc/en-us/articles/201752654-Minimum-and-Recommended-System-Requirements#wq2
