Hey guys!
So I hope i'm not breaking any forum rule when posting this (too lazy to read them :S)
I just wanted to shere my thoughts on this new AIO liquid cooler from Arctic.
I was trying do decide for so long, Linus always says to get the biggest radiator you can fit in your case... For me it was a 120mm.
With all the reviews i've seen, most 120mm AIO's are not really worth it, but i just wanted it, if not for the cooling then for the esthetics :)
Then i came across this new Arctic Freezer 120mm AIO. I've used Arctic's products in the past and i always loved them.
So i went for it, and long story short, It's amazing!!
Iv'e got it mounted at the front in a push-pull (it comes with two fans' and frankly its too thick for just one fan) configuration.
It lowered the temps of my FX-8350 @ 4.7 by 20+ degrees (thermal margin went up by 20+ as measured in AMD overdrive)  compared to the Hyper 212x i had before, and it does that being very quite. I have no way to measure noise levels, but i cant say it sounds any different from the hyper 212x, and both are not audioble when the case is closed (PC is under the desk) .
So thats it i guess. I'm so happy with it i had to share, I'm sure i'm not the only one with that problem.
If you have any questions after reading my thoughts feel free to ask.
V3gab0nd.
https://linustechtips.com/topic/577581-arctic-freezer-120/
