1 minute ago, Mr.Meerkat said:
@Chewique
Take out the display I put in pcpartpicker and add the monitor lawrence suggested in your other thread ( LG 22MP55HQ-P )
Found it in PCPartPicker :D
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  (£259.99 @ Amazon UK)
Motherboard: Gigabyte GA-H110M-H Micro ATX LGA1151 Motherboard  (£50.85 @ Ebuyer)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  (£57.83 @ Ebuyer)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (£68.99 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£39.95 @ Amazon UK)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  (£259.98 @ Ebuyer)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  (£34.98 @ Amazon UK)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (£79.99 @ Novatech)
Monitor: LG 22MP55HQ-P 60Hz 22.0" Monitor  (£105.84 @ Amazon UK)
Total: £958.40
Generated by PCPartPicker 2016-04-05 20:21 BST+0100
it is 8 pounds over 950 tho...
Very nice! thank you!
MY RIG
I5 6600k
16gb Corsair vengeance 2666mhz
MSI Gaming X 1070
WD blue 2tb
samsung 850 evo 250gb
EVGA supernova G2 650w
https://linustechtips.com/topic/577243-pc-help/page/2/#findComment-7550309
27 minutes ago, Streetguru said:
You could either go with a single 1440p display or dual 1080p displays if you need to do some productivity work as well as gaming, this 1440p display has a highly adjustable stand built in
380 is a bit weak for 1440p though, a 390 would be preferable, but that would mean dropping your i7 to an i5 which isn't preferable for rendering.
suppose you could drop the SSD to fit it in, but I'd say getting a good primary display is going to be the best option over any of that
Of course if you're feeling extra crazy and you want to buy one display forever, there is a 27" 4k IPS free-sync display at only 360 pounds
https://uk.pcpartpicker.com/part/lg-monitor-27mu67
PCPartPicker part list: http://uk.pcpartpicker.com/p/TJ8b4D
Price breakdown by merchant: http://uk.pcpartpicker.com/p/TJ8b4D/by_merchant/
Motherboard: Gigabyte GA-H110M-S2HP Micro ATX LGA1151 Motherboard  (£58.84 @ More Computers)
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory  (£51.99 @ Amazon UK)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  (£53.98 @ Amazon UK)
Video Card: XFX Radeon R9 380 4GB Double Dissipation Video Card  (£159.98 @ Novatech)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  (£37.32 @ Ebuyer)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  (£56.00 @ Amazon UK)
Monitor: Asus PB258Q 60Hz 25.0" Monitor  (£254.99 @ Ebuyer)
Total: £973.04
Generated by PCPartPicker 2016-04-05 20:01 BST+0100
When do you think that the next gen cards will be out? also what will their prices be?
MY RIG
I5 6600k
MSI Gaming X 1070
WD blue 2tb
https://linustechtips.com/topic/577243-pc-help/page/2/#findComment-7550317
5 minutes ago, Chewique said:
What would the performance drop be in a game such as gta v? like 60 to 50? or bigger?
Going to be fairly capable for 1080p ultra, and the display will change it's refresh rate to match your fps, as it's a free-sync display
of course it would be better to drop the settings a bit and get much smoother game play with higher fps
PC hardware almost always costs about the same and gives you more performance when new stuff comes out, but it's a few months away, would only be worth going that route if you have to drop to a 380 to get a higher end display
https://linustechtips.com/topic/577243-pc-help/page/2/#findComment-7550320
No problem, I guess Streetguru's 144hz idea isn't too bad either if you like playing competitive shooters such as CS:GO and want to have an edge or you want a more smooth looking desktop (but in my opinion, trading a worse looking display in terms of colour and a worse GPU for a faster refreshing display is not worth it but you know, it's your money so do what ever you wanna :D. Hell, you can create your own build and we can give you comments and guidelines on whether it's going to be good or not).
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/577243-pc-help/page/2/#findComment-7550353
Hehe :D Well I'm deciding between a nice monitor and a r9 380x or a r9 390 and a 2010 apple cinema display monitor :/
MY RIG
I5 6600k
MSI Gaming X 1070
WD blue 2tb
https://linustechtips.com/topic/577243-pc-help/page/2/#findComment-7550369
Well 1440p or a 144hz is beneficial in different ways compared to a 1080p IPS panel but in the end, it's your decision on what you get (and what you like more :D).
https://linustechtips.com/topic/577243-pc-help/page/2/#findComment-7550377
Im probably going to go for a 380x and a nice monitor
MY RIG
I5 6600k
MSI Gaming X 1070
WD blue 2tb
https://linustechtips.com/topic/577243-pc-help/page/2/#findComment-7550383
go for it :D Have fun building it!
https://linustechtips.com/topic/577243-pc-help/page/2/#findComment-7550412
