I recently bought a NZXT HUE+ and it's working great except for one thing. The little box that controls the LEDs has a white light stripe on it. Even tough I have turned off my computer it's still turned on. Why is that and how do I fix it?
It gets power from a molex 5V and is also connected to the motherboard via USB.
https://linustechtips.com/topic/576629-nzxt-hue-light/
I think you can't if its 5V. 5V leds only turn off when the PSU is turned off. You could put some black tape on it, though.
Project Pluto
i3 4170 MSI H97 PC Mate MSI R9 380 2GD5T @ 1095MHz Kingston HyperX Fury Blue 2x4gb @ 1600MhzWD 1TB Blue • be quiet! Pure Rock • NZXT S340 Black XFX TS 550w • BenQ GW2265HM
https://linustechtips.com/topic/576629-nzxt-hue-light/#findComment-7543273
I would say check the software, but other than that there really isn't a way.
You could get an inline molex power switch, but that would add a lot of cabling and a button to flip when ever you want to turn it off.
Try taping a piece of paper over it. I have paper taped to so many lights it's not even funny lol
https://linustechtips.com/topic/576629-nzxt-hue-light/#findComment-7543277
5V should still turn off when the computer shuts down. The separate 5VSB rail stays up, though.
The LED strips may be powered by the molex adapter, but the controller box may be powered by the USB header.
Check your mainboard manual to see if there are separate USB headers powered off the 5V and the 5VSB rail. Some motherboards offer multiple USB headers where some turn off with the computer, and some don't (so you can for instance still charge a phone or wireless headset when you're not using the computer). They are also usually marked with a different color.
Alternatively, check your BIOS settings. Some motherboards don't have separate USB and power-USB headers, but allow you to turn that feature on or off for all or some USB headers from the BIOS.
daily driver
Intel Core i7-950 | ASUS SABERTOOTH X58 | 6x2GB Corsair XMS3 PC3-12800 | ASUS GTX970 STRIX | SB X-Fi Titanium
Samsung 840 EVO + WD Caviar Black | Fractal Define R3 | Phanteks/Noctua/NoiseBlocker cooling | Windows 10 Pro
MacBook Pro (13-inch Mid 2010)
Intel Core 2 Duo P8600 | Apple Mac-F222BEC8 | 2x4GB Samsung PC3-8500 | GeForce 320M
SanDisk SDSSDP | Apple A1278 Aluminium Unibody | macOS Sierra
Microsoft Lumia 950
Qualcomm Snapdragon 808 | 3GB RAM | Adreno 418 | Windows 10 Mobile
daily driver 2
Intel Core i5-750 | ASUS P7P55-M | 4x1GB Elpida PC3-8500 | Sapphire Radeon HD5870 | SB X-Fi Xtreme Music
Crucial M4 + WD AV-GP Green | Fractal Define R3 | Scythe/Gelid/Noctua/NoiseBlocker cooling | Windows 10 Pro
MacBook Pro (15-inch, Mid 2012)
Intel Core i7-3615QM | Apple Mac-4B7AC7E434945597E | 2x4GB Samsung PC3-12800 | GeForce GT650M
WD Blue | Apple A1286 Aluminium Unibody | macOS Sierra
server
AMD Athlon 64 LE-1620 | Jetway JNC62K | 2GB Corsair Value Select PC2-6400 | GeForce 8200 IGP
WD Caviar SE16 + AV-GP Green + 2x Red | Chenbro ES34069 | Scythe/Nexus/Noctua cooling | Windows Home Server
coming soon: Eve V
Intel Core i7-7Y75 | Skybay U3E1 | 2x8GB Samsung PC3LP-14900 | Intel HD 615
Intel 600P | Eve V Aluminium Unibody | Windows 10 Pro
https://linustechtips.com/topic/576629-nzxt-hue-light/#findComment-7543331
5V soft power is on all the time unless you turn your PSU switch off
if you dont want the white light then put some black electrical tape over it
https://linustechtips.com/topic/576629-nzxt-hue-light/#findComment-7543333
