Power Consumption of R9 380
DGB
What is the actual power consumption of the r9 380?
Red (Soon to be Retired)CPU: FX-8350 Cooler: CM 212 Evo  GPU: Gigabyte GTX 1060 6GB RAM: 16 GB Kingston HyperX 1866MHz Mobo: Asus M5A97 LE R2.0 SSD: Kingston 128 GB (Boot), Samsung 860 EVO 500 GB (Main Games) HDD: WD Black 1 TB (Storage + Older Games) PSU: EVGA W1 500W Monitor: Dell ST2220l 21.5". Peripherals: Razer Blackwidow Ultimate 2013 Keyboard, Razer Deathadder Mouse, SteelSeries mosepad,
TDP: 190 watts
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
It depends on the load.
Why, though?
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
Why, though?
wondering if my psu can handle it
Which model is it?
The power draw of an entire system WILL vary depending on the components you use (i.e. CPU, GPU, RAM, motherboard, etc).
As a general "rule of thumb," a quality built 500W / 520W / 550W will be sufficient for a whole system with a single graphics card -- lean towards the 520W and 550W if overclocking is considered.
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
250-300w
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
Around 190w in graphic intensive games.
Around 230w in power virus Furmark.
According to TinyTomLogan, it's about 150W at stock and 190W when OCed
Should start off at 190w in which it could increase to 250w after overclocking.
CPU: Intel Core i3 4370 (3.8GHz, 2C/4T) GPU: AMD R9 380X 4GB
190W is the peak possible. AMD rates TDP based on maximum possible with the +20% power target.
Source: http://www.guru3d.com/articles-pages/amd-radeon-hd-7850-and-7870-review,6.html
The boards' overall power consumption from idle to load is excellent really. Expect an idle wattage of roughly 10 Watts and, when the monitor goes into power save mode, the card throttles down even lower towards 3 Watts. The TDP for the 7850 we measured at roughly 110W and the 7870 at 130 Watt.
AMD advertises the board power at 130W (7850) and 175W (7870), board power is different then the TDP. If you try and visualize the power control settings slider in the Catalyst center, then you'll realize that you can increase it 20% meaning at default the TDP is roughly 20% lower then AMD's 130W for the 7850 and 175W for the 7870.
  • Reverse calculate that and at default the TDP for 7850 would be 130Wx0.80=104W
  • Reverse calculate that and at default the TDP for 7850 would be 175Wx0.80=140W
According to that a 380 is around 150W at stock and 190W when OCed to the max
Whoa. Totally didn't know that. Cheers for that then.
