monitor split screen
jol159
does anyone know how to setup a split screen windows 10?
Edited by jol159
drag one window to the top left corner of your screen and let it snap into place on your left hand side. Then do the same thing on the top right hand corner of your screen with the other window you want to use.
Intel i7-5820k OC'ed to 4.2GHz @1.225 V; w/ Corsair H110i GTX2x Asus Strix 980ti's; Asus Rampage V Extreme; 16GB (2x8GB) Crucial Ballistics GDDR4 RAM; EVGA 1000P2 psu
http://www.3dmark.com/3dm/8608142 boost clock of 1493MHz
https://pcpartpicker.com/user/jjar35/saved/#view=ghCWGX + 43" 4k Vizio M-Series TV
Thanks
  • 2 years later...
You can split the screen of windows 10 by using snipping tool or by using short keys.
Some shorts keys are
Windows+Right Arrow and Next Windows+Up Arrow for right top corner
Windows+Right arrow and next windows+down arrow for right bottom
Windows+left arrow and then windows+Up arrow for left top corner
windows++Left arrow and then windows+down for left bottom corner
For knowing about snipping tool read the article https://windowsclassroom.com/how-to-split-screen-on-windows-10/
