Hello, I was thinking about doing custom liquid cooling loop in my computer. I currently have a corsair h100i gtx AIO, but I would like to try my hand at a custom loop. I was wondering what I would need, what some of the best quality parts are, and how much all of this would cost me?(**I'm not looking to break the bank either...***) Any and all help would be great , Thank you!
https://linustechtips.com/topic/575415-liquid-cooling-help/
This might give you some ideas:
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/575415-liquid-cooling-help/#findComment-7531958
If you wanted to say start with just a CPU only loop the kits from EKWB are a great base for a watercooling loop and the further expand of you plan to add in a GPU. For an estimate of how much it would be for a single CPU and GPU loop it is usually around $500USD for a quality loop.
https://www.ekwb.com/shop/ek-kit-p240
https://www.ekwb.com/shop/ek-kit-p360
https://linustechtips.com/topic/575415-liquid-cooling-help/#findComment-7532047
