1 minute ago, Assassin56 said:
a friend of mine gave me a new 2.5" 750 gb hard drive still in the package for my desktop. i put it in but it only shows up as 60 gbs and 299 mb. it says 750 gbs on the hard drive. does anyone know why it is only showing 60 gbs?
Format it, / delete the partition and reformat it etc
https://linustechtips.com/topic/575072-25-hard-drive/#findComment-7528643
Computer management>storage>disk management
Look for the right disk/drive and delete the parts or just format them all via right click menu
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/575072-25-hard-drive/#findComment-7528654
What does it show in Disk Management?
Gaming Rig:
CPU: AMD Ryzen 3600X @ 4.1GHz All Cores - Ram: 16GB Corsair VENGEANCE - GPU: 5600XT MSI Gaming X - Storage: Samsung EVO 840 250GB - 2TB Seagate Drive OS: Win10
HTPC Rig:
CPU: i5 6400 - Ram: 16GB - GPU: 970 GTX - Storage: 120 Kingston SSD & 2x 1TB Seagate Drive OS: Win10
https://linustechtips.com/topic/575072-25-hard-drive/#findComment-7528781
If you right click on the 60gb should day extend click this and follow on screen insturctions
Gaming Rig:
HTPC Rig:
https://linustechtips.com/topic/575072-25-hard-drive/#findComment-7528987
