Please Help
Go to solution Solved by Trey222,
Here is mine. In CAD.
PCPartPicker part list: http://ca.pcpartpicker.com/p/4Hp9xr
Price breakdown by merchant: http://ca.pcpartpicker.com/p/4Hp9xr/by_merchant/
CPU: Intel Core i3-6300 3.8GHz Dual-Core Processor  ($179.99 @ NCIX)
Motherboard: ASRock H110M-DGS Micro ATX LGA1151 Motherboard  ($61.50 @ Vuugo)
Memory: Avexir Budget Series 8GB (1 x 8GB) DDR4-2133 Memory  ($44.98 @ Newegg Canada)
Total: $286.47
Generated by PCPartPicker 2016-03-31 12:52 EDT-0400
Here's a Haswell option:
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.89 @ OutletPC)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($44.89 @ OutletPC)
Memory: Crucial 8GB (1 x 8GB) DDR3-1600 Memory  ($28.99 @ SuperBiiz)
Total: $248.77
Generated by PCPartPicker 2016-03-31 12:48 EDT-0400
Here's a Skylake option:
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($194.99 @ Newegg)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($41.38 @ Newegg)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory  ($35.99 @ Newegg)
Total: $262.36
Edited by Crowes
These are USD. Apologies.
Eien nante naito iikitte shimattar  /  Amarinimo sabishikute setsunai deshou
Dare mo ga hontou wa shinjitai kedo  /  Uragirarere ba fukaku kizu tsuite shimau mono
https://linustechtips.com/topic/574582-please-help/#findComment-7523521
9 minutes ago, NickFTW4 said:
my budget is $300 for a cpu ram and motherboard
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($155.25 @ shopRBC)
Motherboard: ASRock B150M-HDS Micro ATX LGA1151 Motherboard  ($84.75 @ Vuugo)
Memory: G.Skill Ripjaws V Series 8GB (2 x 4GB) DDR4-2133 Memory  ($46.65 @ DirectCanada)
Total: $286.65
Generated by PCPartPicker 2016-03-31 12:53 EDT-0400
With better motherboard:
Motherboard: ASRock H170M Pro4S Micro ATX LGA1151 Motherboard  ($105.00 @ Vuugo)
Total: $306.90
Generated by PCPartPicker 2016-03-31 12:55 EDT-0400
https://linustechtips.com/topic/574582-please-help/#findComment-7523525
Total: $286.47
My Work in Progress PC http://linustechtips.com/main/topic/522048-xeon-build/ <-- That PC was built but never booted:(
My Work in Progress PC 2.0 https://linustechtips.com/main/topic/540583-xeon-build-20-code-name-xenox (Hopefully this one boots.)
https://linustechtips.com/topic/574582-please-help/#findComment-7523531
1 minute ago, NickFTW4 said:
I dun really want a dual core
It's hyperthreaded. Not as good as four full cores, but close.
https://linustechtips.com/topic/574582-please-help/#findComment-7523549
There is this. Probably the cheapest i5 system. Also remember that while the i3 is a physical dual core windows will see it as a quad core because it is hyperthreaded.
PCPartPicker part list: http://ca.pcpartpicker.com/p/rGsRZL
Price breakdown by merchant: http://ca.pcpartpicker.com/p/rGsRZL/by_merchant/
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($243.35 @ Vuugo)
Total: $349.83
Generated by PCPartPicker 2016-03-31 12:56 EDT-0400
https://linustechtips.com/topic/574582-please-help/#findComment-7523561
Well would that be better then $270 for
GIGABYTE GA-78LMT-USB3 (rev. 6.0) AM3+ AMD 760G + SB710 USB 3.0 HDMI Micro ATX AMD Motherboard
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
AMD FX-6300 Vishera 6-Core 3.5 GHz (4.1 GHz Turbo) Socket AM3+ 95W FD6300WMHKBOX Desktop Processor
https://linustechtips.com/topic/574582-please-help/#findComment-7523569
Yes. The FX-6300 is not the best.
https://linustechtips.com/topic/574582-please-help/#findComment-7523575
Why not? :o
AMD CPU do not have great IPCs (instructions per clock) and even the I3 6100 even beats it in mutithreaded benchmarks.
https://linustechtips.com/topic/574582-please-help/#findComment-7523595
Just now, NickFTW4 said:
What would you suggest?
 The I3 6300. It would perform a lot better in pretty much everything.
https://linustechtips.com/topic/574582-please-help/#findComment-7523607
Hmm okay but the motherboard will work okay with either cpu right?
No. AMD and Intel CPUs are VERY different. Intel uses pads and and uses pins. The motherboards are not capable at all. The i3 6300 uses socket LGA 1151 while while the FX 6300 uses AM3+.
https://linustechtips.com/topic/574582-please-help/#findComment-7523643
