i have picked out parts for my gaming set up after some research my only questions are
- are there any bottlenecks
- will my lepa rad and fans fit in the case
any tips on different parts my budget is not high only €1200
here is my list
http://pcpartpicker.com/p/WvRfYJ
the case would be the CiT Vanquish red leds or any other one that i find is better
i wanted fractal design r4 w/window but doesn't ship to Ireland.
https://linustechtips.com/topic/573915-my-first-build-concerns/
Why are you using the US version? you know you will pay tons of import tax and shipping costs etc, would the UK one not be a better idea? (are you NI or ROI)
Also id get an i5 over the AMD CPU
https://linustechtips.com/topic/573915-my-first-build-concerns/#findComment-7516639
1-Avoid the V300 SSD, it had its NAND changed and is now significantly slower than before.
2-The FX 8350 has poor single core performance which matter a lot in games, get a locked skylake i5 (i5 6500) with a H110/B150 board since that will do better in many games.
3- A 550-650W PSU is more than enough for your build.
4- Coolers come included with thermal paste, no need to buy one.
5-That mouse looks fishy
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/573915-my-first-build-concerns/#findComment-7516652
1 minute ago, Fear_incarnated said:
i have the parts on pp to see them together im getting them off amazon and why i5 over the amd cpu
will i also need to change anything else if its not amd (noob right here)
because the AMD CPUs are not very good for gaming compared to intel CPUs, the i5 would be much stronger for gaming, ,yes you would need to change the motherboard
And dont get the V300 SSD,
https://linustechtips.com/topic/573915-my-first-build-concerns/#findComment-7516661
so any suggestions for a good motherboard for gaming and the i5 proccesor?
I5 6500 and any H170/B150/H110 motherboard with 4 RAM slots would be fine (since you can't overclock it no need to worry much about the board, don't spend much on it).
https://linustechtips.com/topic/573915-my-first-build-concerns/#findComment-7516668
https://uk.pcpartpicker.com/part/intel-cpu-bx80662i56500
https://uk.pcpartpicker.com/part/amd-cpu-fd832ewmhkbox
Can you explain how the intel one is better than the amd?
https://linustechtips.com/topic/573915-my-first-build-concerns/#findComment-7516741
Good thing is someone did this before in this forum:
http://linustechtips.com/main/topic/316130-best-amd-processor-for-gaming/#entry4296531
https://linustechtips.com/topic/573915-my-first-build-concerns/#findComment-7516754
1.Since you are not overclocking stay with the stock intel heatsink, you can upgrade if you need to further down the line.
2. Since you only have a limited budget, why go with a K70? there are cheaper MX Red keyboards out there, e.g. logitech g610 (http://gaming.logitech.com/en-gb/product/g610-orion-red-keyboard)
3. Spending 10GBP or 20usd or whatever on thermal compound is unnecessary to put it delicately.
4. Shops in the UK such as ocuk will ship to Ireland at a what I believe is a fairly inexpensive cost.
5. Get all your parts from a single etailer if possible to avoid paying shipping 2 or 3 times.
PCPartPicker part list: http://uk.pcpartpicker.com/p/Pc4XCJ
Price breakdown by merchant: http://uk.pcpartpicker.com/p/Pc4XCJ/by_merchant/
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  (£151.98 @ Ebuyer)
Motherboard: ASRock B150M Pro4S Micro ATX LGA1151 Motherboard  (£62.16 @ More Computers)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  (£55.92 @ More Computers)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (£67.98 @ Novatech)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£54.98 @ Novatech)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  (£249.59 @ Overclockers.co.uk)
Case: NZXT S340 (Black) ATX Mid Tower Case  (£55.78 @ Amazon UK)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  (£51.99 @ Amazon UK)
Monitor: BenQ GL2460HM 60Hz 24.0" Monitor  (£104.99 @ Amazon UK)
Keyboard: Corsair K70 Wired Gaming Keyboard  (£119.98 @ Amazon UK)
Mouse: SteelSeries Rival 100 Wired Optical Mouse  (£29.97 @ Ebuyer)
Total: £1005.32
Generated by PCPartPicker 2016-03-30 12:05 BST+0100
1. Go to the by merchant price break down, i think only 3 components can't be shipped by amazon uk for essentially free.
2. Dabs have an irish store I believe
3. you could change the HDD to a cheap 1tb one, get 1x8gb of RAM, 500w PSU, cheaper SSD to get something like 60GBP off, whcih with the current exchange rate puts you at 1195 Euros (http://uk.pcpartpicker.com/p/RdxhnQ)
6700k|Hyper 212 EVO|Asus Z170 Deluxe|GTX970 STRIX|16gb 2400mhz Teamgroup memory|Samsung 950 PRO+ 2TB Seagate HDD| CM Realpower M1000|H440
Take a look at my flickr?:  https://www.flickr.com/photos/150012948@N06/
https://linustechtips.com/topic/573915-my-first-build-concerns/#findComment-7516760
6 minutes ago, Fear_incarnated said:
It seems like AMD dropped the prices again for the FX processors again, though since there is no processor from AMD that is above the FX 8350 I don't think we will have a i5 equivalent.
https://linustechtips.com/topic/573915-my-first-build-concerns/#findComment-7516765
