Radiator Help
Go to solution Solved by Octavialicious,
240mm is fine for a CPU, but please don't waste money on cooling your RAM (unless you're doing it for looks)
With that being said you might consider an all in one cooler if you cool only your CPU, unless you want to add a GPU later :P
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/573847-radiator-help/#findComment-7516004
240 is definitely enough
https://linustechtips.com/topic/573847-radiator-help/#findComment-7516011
