Thanks for taking the time to read my post.
Like the title says I am looking for a new wireless headphones!
I don't want to go over 200CAD$
The most important thing is that they are wireless, that comes first.
I am looking for more of a gaming headset, (with a mic) But I've heard from many different places that you should just go with a real pair of headphones with a external mic?
If that is the case please recommend me a good pair of wireless Headphones and a desk Mic
I prefer headphones that go around your ear, and that are comfy for long use.
Couple options I've been looking at are the H2100 G930 Void and G933. What would you recommend?
https://linustechtips.com/topic/573801-best-budget-wireless-headset/
2 hours ago, zane2268 said:
Please read the post, I said Wireless headset's Neither of those are wireless. I already own the cloud 1's
Wireless headsets are usually garbage or overpriced. The only good ones you'll find are probably over $200 like the G933's (meh and overpriced), Astro A50's (Overpriced AF). The G930's are wireless but still, sort of dated and not the best ones.
23 hours ago, SomebodyOnEarth said:
I would check the Hardware canucks yt page. they have some headphone reviews, but I personally enjoy the Audio Technica ATH-M40x headphones with a mod mic.
hi,
Im looking at the Audio Technica M50X would you recommend these im also looking for a mic to use with them would you recommend any good ones?
4 minutes ago, SomebodyOnEarth said:
Are you looking for one to attach to your headphones to make them a headset, or do you want a desktop mic?
I'm looking at both options at the moment but I think im leaning more towards attaching them to the headphones.
