So, my network speed has dropped significantly sometime in the past, not terrible sure when. I've gone from 7mb/s download speed to 2.5-3.2mb/s. There was possibly a windows resintallation in that time, so i'm not sure if that was it. Just simply trying to get my internet speed back ujp to what it was at. Any ideas on what it might be, or suggestions for things that could help?
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/573772-network-speed-dropped-significantly/
whats the speed directly from your modem? whats your speed directly from your Router? Run a speed test from those two plus from your current setup where you think its slowing down.
I had an issue like this but can't be sure if its the same one.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
I assume that would involve me plugging my computer straight into the output of the modem?
The speed directly from my router is ~3mb/s at best, as that's what i'm currently getting. It used to be ~7mb/s. All running over ethernet.
yes plug it directly into the router, AND in your modem (two separate tests, a LOT of my issues were router based, so knowing what your getting from the router, then the modem , before your network even comes into play, is important to know).
Did you just test it by directly plugging in? I dont think you would know the speeds from router+modem if you didnt know for sure you plug directly into it.
The ~3mb/s is from Modem->Router->PC with all other network devices online. Gimme a second to try going directly from the modem to my PC.
Modem yields full speeds!
FUCK YOU ROUTER!
Hell, Modem yeilds better results than I had a while ago. upwards of 8mb/s
FUCK YOU ROUTER!
I figured. I had this happen before and its annoying AF. Still happens once a month.
The only thing that would fix this for me was a complete router reset, although a reboot could also fix it, so try that first.
Alrighty. Do you know what router settings might be making this happen? I remember a while ago my friend somehow made my entire network implode when I told him to power cycle the router, and that required alot of modem rebooting, router rebooting, and several router resets before the network came back up.
Specific router in question is a WNR2000v4. Not a PK5000Z like I thought.
I could never figure it out, searched every possible thing and couldn't find any information about it. I have another issue where I randomly lose internet and its because my Modem decides to randomly stop detecting my router and refuse to do so until i do a modem reboot, but I never found a link between the two. Its frustrating not being able to know what causes the issue but knowing how to fix it and not knowing why it works.
EDIT: im also not familiar with CenturyLink's interface. Im only familiar with Cisco home and commercial routers/switches, and Netgears home routers (Im currently using an R7500)
12 minutes ago, FruitBasketSilex said:
Specific router in question is a PK5000Z.
Fucking text editor.
I meant WNR2000V4. I had it wrong. ^-^ that's what I get for not double checking.
Router is refusing to start up or something.
It's lights are on as normal, the modems lights are on as normal, and the link light is flashing, but the router is putting out a wifi signal, but not allowing any traffic.
Nothing in/out. Unable to access router page via 192.168.1.1
Uhhh, apparently my router now told me my IP was changed to 10.0.0.1?
turn off router, turn off modem, wait a minute or two, turn on modem, wait like 2 minutes, then turn on router, and wait for it to boot up. Are those the steps your following?
did you reset it or reboot?
That was post-reset I believe. It'connectionsly failing to detect the internet connection now that it's actually working.
Fucking NetGear Genie is no help at all.
"Did you power cycle the modem"
"Did you make sure the yellow cable is plugged in"
After doing this again:
IT JUST FUCKING WORKS.
Full speed.
Through router.
It.
Just.
Fucking.
Works.
Fuck networking. Jesus christ.
