Linux+windows boot help!
Go to solution Solved by manikyath,
3 minutes ago, Abel225 said:
The problem is my bios can't find my SSD in boot options. If I remove the openSUSE drive than it timesout and will find one that has an os thus I can start windows...
boot option -> hard drive priorities.
boot priorities work as following:
first you sort by device:
- removable
- optical
- hard drive
- network
and then for those ones you can individually set their priorties.
Hi
I just installed openSUSE on a separate hard drive in my rig. Now when I try to boot into windows witch was installed before linux, my motherboard only sees openSUSE booter. The only way for me to boot from my drive is to disable/remove the drive that linux was installed to. But I want to format that drive with windows. But I can't boot with it being in my machine. Is there a way to bypass this? please don't tell me I have to bios update/flash... I'm a bit scared of that. My mobo actually has an os x bootloader aswell. And I can't get that out without flashing the bios.
Thanks for the help!
Intel core I5 4460, Gigabyte H97M-HD3, Gigabyte gtx 760, 8 GB corsair value ram, Thermaltake core v21, Thermaltake Smart 630W PSU
Alcatel OneTouch D5... IT WORKS!!
http://pcpartpicker.com/p/BxMjTW
https://linustechtips.com/topic/573553-linuxwindows-boot-help/
https://linustechtips.com/topic/573553-linuxwindows-boot-help/#findComment-7512801
SATA is hot-swappable. That means you can just unplug the Linux drive, boot in windows, and then plug in the linux drive while PC is booted in windows. Maybe then it will be seen in windows and can be reformatted from there.
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
https://linustechtips.com/topic/573553-linuxwindows-boot-help/#findComment-7512828
- removable
- optical
- hard drive
- network
https://linustechtips.com/topic/573553-linuxwindows-boot-help/#findComment-7512836
I thought onboard sata is not hot-swappable. But if it is than that would solve most of my problem.
https://linustechtips.com/topic/573553-linuxwindows-boot-help/#findComment-7512839
except both the motherboard and hard drive need to support it.
https://linustechtips.com/topic/573553-linuxwindows-boot-help/#findComment-7512841
- removable
- optical
- hard drive
- network
I'll check this out! thanks
https://linustechtips.com/topic/573553-linuxwindows-boot-help/#findComment-7512843
SATA is hot-swappable i have a friend who does this all the time.
Current Build: Core i7 4790k @ 4.6, Asus Maximus VII Hero, Corsair Vengeance Pro 2400mhz 8gb (2x4gb), GTX 980ti, NZXT Kraken X61, Fractal Define R5  EVGA Supernova B2 850w, Some 300gb hard drive.
http://pcpartpicker.com/p/W7CNrH
https://linustechtips.com/topic/573553-linuxwindows-boot-help/#findComment-7512874
