I hope that I may be able to get some better answers than I am on the Web. I have a Lenovo w520 with a i7-2720. 32GB RAM. It also has a Intel HD Graphics 3000 and a Nvidia Quadro 1000M. I dont have any complaints with the computer and it serves me well with my audio editing. I am getting back into the world of gaming and my wife wont let me build another gaming pc. So what I want to know, is there a trust worthy external dock that can be used with the pci express card slot i have to run a decent gpu?  I came across this device but it only supports 1.1  nothing higher (that I know of.)
http://www.amazon.com/SAWAKE-External-Independent-expresscard-version/dp/B013P0T97G?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_sfl_title_1&smid=A2B8YUJLML2GI6
I hope this all makes sense and that someone can at least point me in the right direction.
Thanks
https://linustechtips.com/topic/572990-help-external-gpus/
It won't work unless you have Thunderbolt
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7506845
Does you laptop have a expresscard slot? It'll work, but it depends on the speed that the slot works at on your laptop.
CPU AMD Ryzen 5 3600x | GPU GIGABYTE GTX 1070ti WINDFORCE | MOBO ASUS Prime X570-P | MEMORY XPG Spectrix 2x8GB 3200MHz  | PSU OCZ Zx 850W | CASE NZXT H440
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7506909
Not exactly true, some expresscard slots can run at PCI-E 3.0 4x speed
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7506934
Still going to bottleneck most GPUs unless you go back to 6000/500 series
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7506937
Not by much tho.
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7506943
Not by much tho.
A guy had 290 CF on PCIe 3.0 x4 - couldn't get them past 50% usage
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7506944
I think you're talking about about PCI-E 2.0, because 4x slots are usually run on the chipset  which is 2.0
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7506963
I think you're talking about about PCI-E 2.0, because 4x slots are usually run on the Chinese which is 2.0
No, 3.0. Nvidia don't even allow their cards to run on 3.0 x4 IIRC
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7506967
Maybe that'll help you out somehow.
Budget Rig "Curable":     | FX 6300 @4.5Ghz | Asus R9 270x | Asus Crosshair IV Extreme | 16GB HyperX Beast | 120GB PNY SSD
Tablet "Buddy":                 Trekstor Wintron 10.1|
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7506976
"Computer ports with Thunderbolt 3 provide 40Gbps"
Which is equivalent to PCI-E 4x 3.0
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7506996
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7507029
PCIe 3.0 4x is 4GB/s
What that means is that a PCIe 3.0 x4 connection (3.94GB/s) should have nearly the same bandwidth as PCIe 1.1 x16, or PCIe 2.0 x8 (both 4GB/s). Modern GPUs use a x16 PCIe 2.0 or 3.0 interface. That doesn't mean they always run at x16 speed, though
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7507034
What are you going to be using as a EGPU?
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7507041
im not sure yet i was thinking of a 960 or 970. but it has been a long time since i last messed around with pc gaming and video editing. do you have a suggestion that could work with my setup without breaking the bank?
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7507057
Those wouldn't work. Nvidia drivers don't allow modern GPUs to run slower than PCIe 3.0 x8
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7507069
It will, it's SLI that they don't allow on slower than 8x
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7507079
It will get bottlenecked though - even if it somehow works (which I doubt) it won't go past 50% usage thus making the 970 essentially a 950 or lower
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7507082
ok so is there a decent option to use that wont totally suck? i wont be doing any heavy gaming but i want something that is better than the   Nvidia Quadro 1000M  that is in my laptop now?
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7507090
Probably a 660? Maybe 670?
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7507094
10 minutes ago, daniel2carr said:
I also plan to run 2 monitors when i am editing music
Please don't listen to this guy, are you using CUDA accelerated programs or will OpenCL work?
https://linustechtips.com/topic/572990-help-external-gpus/#findComment-7507098
