SSD read/write speed vs. price
Solved by Moonzy,
1 minute ago, Airplanegun said:I currently have a Kingston Hyper X Fury 120GB installed in my system. I'm looking to get a larger capacity SSD to run along side it. What would be your recommendation? (I started looking at all this when I came across the ADATA SP550 being at such a good looking price compared to everyone else and wanted to know why.)
well i generally recommend people getting the 850 evo,
its a good balance between price, reliability and performance
and i normally mix 250gb 850 evo with 2tb of wd blue HDD,
so you get speed for your softwares and you get the capacity to store files like movie and songs
if you want the best value per gb, the 850 evo 500gb + wd blue 3tb ![]()
