Hi, I am trying to spec out parts for my first PC build.
CPU: Intel skylake i5 6600k
GPU: GTX 970
Mobo: one with the proper socket for cpu (ATX)
power supply: Something that will work
Case: a midtower ATX one
Ram: preferably 16 gb
Since i am completely new to building a PC, i do not know what i should do for cpu cooling (water or air) because water is quiet, but risky for a first time builder. Then Air can be loud, but i have headphones that i use when gaming. Also i have a cousin who has a custom build PC and he says water cooling is the best. Anyways i also don't know what to do i choose air cooling because of the ram clearance issues i have seen. Basically any advice would be helpful
https://linustechtips.com/topic/572667-clueless-about-building-a-pc/
What is your budget first ... so we can build/help you.
Magical Pineapples
GPU: GTX 970
Try out the site PCPartPicker. It will automatically filter out any parts that are incompatable, and you can share your list with others. Before we (anybody who replies) can decide what's a good set of parts for you, you need to let us know how much you're willing to spend.
My friend didn't realize until today that his graphics card was worth $1000
Is budget an issue? Water cooling is only as dangerous as you are careless... Watch tutorials, buy good parts, change water on the recommended dates. You'll be fine. Water cooling alloys for overclocking, since you have a "k" series you will be able to do this. I am a first time builder and after a great amount of research am planning a custom loop including the GPU :)
Air is actually usually is quieter than water (AIO), unless you go for a custom loop. I would recommend something like the Cryorig H7/H5, low cost, great performance, great looks. Watercooling (AIO and custom loop) can and usually does yeild slightly better temps and a little more overclocking (plus they look sweet), but pretty much any decent air or water cooler will keep even an overclocked cpu under the thermal throttle limit (which is when the cpu slows down to avoid overheating) , so there won't be any real performance difference. If you stick with low profile ram like the Corsair LPX or the Hyper X fury, you should be fine.
I like good humans and good food
1 minute ago, MajorGoob said:
2000 USD? Or CAD?
cad
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
Ok. Wow.... 1500 dollars.... mine is like 600..... Are you looking at peripherals too? Perhaps a new screen or keyboard and mouse?
ERROR: VAR_TRAINOFTHOUGHT RETURN CHAR(MISSING)
RESTART  BRAINTHOUGHTS_MAJORGOOB.EXE?
Y                             N
GPU: GTX 970
Welcome to the forum.
It would be great if you could answer the following questions, so we know more about your needs.
  1. I would like to know what you'll use your new PC for. Is it simply for gaming or do you also want to edit videos and pictures or use your PC for something else?
    We can only put a appropriate configuration for you together, if we know what you'll use it for.
  2. What kind of features do you expect your motherboard to have?
    • Does it need SLI/Crossfire support to enable more performance in the future?
    • Do you need a certain amount of USB 2 / 3 / 3.1 ports?
    • How many Gigabit LAN ports do you need?
  3. How should your PC look like? Do you like a certain color scheme? Which color should your case have?
To answer your question about "air or water":
Air is often even quieter than water, simply because you won't need a pump. With the right air cooler you can get great temperatures as well as a near silent system. It really depends on the quality of the fans and the pump. AIOs tend to be pretty loud in comparison with air and custom water-loops.
If you want to get quick answers, you should quote posts! Click the arrow button in the left bottom corner of each post to quote someone.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($324.95 @ shopRBC)
CPU Cooler: be quiet! Dark Rock 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler  ($89.99 @ BestDirect)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($208.45 @ Vuugo)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($89.99 @ Canada Computers)
Storage: Sandisk Z400s 256GB M.2-2280 Solid State Drive  ($86.63 @ DirectCanada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($62.99 @ Canada Computers)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB WINDFORCE 3X Video Card  ($854.99 @ NCIX)
Case: NZXT S340 (White) ATX Mid Tower Case  ($95.05 @ Vuugo)
Power Supply: EVGA SuperNOVA P2 850W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($159.99 @ NCIX)
Total: $1973.03
Generated by PCPartPicker 2016-03-27 20:46 EDT-0400
I would buy white sleeved extensions and this thing would look so damn sexy.
My new Gaming PC.
Case: Coolmaster CM690III, Motherboard: Asus Z170-AR, CPU: I5 6600K 4.6Ghz, OS: Windows 10 HP 64 bit, RAM: X1 8GB G.Skill DDR4, GPU: Galax GTX 960 (Overclocked), Storage: Kingston V300 SSD 120GB(OS), X2 1TB 5400RPM HDD, 500GB Samsung 7200RPM HD, PSU: Cougar RS 750 Watt, Peripherals: Logitech G910 Orion Spark,  World Of Tanks Edition 2014 DeathAdder Razer Mouse And Mouse Pad, Sennheiser HD 518. , Palsonic tftv6042fHD, Logitech Z506 5.1 Surround Sound Speakers
19 minutes ago, Northern_Lion said:
Ok i will post a better part idea in a sec
I have the list done, save for the following question: Do you have a keyboard, mouse, and monitor? If you already have them, then keep your extra $200 CAD I guess. Otherwise, here it is: http://pcpartpicker.com/user/Caminon/saved/mTJ6Mp
Assuming this is only for the rig:
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($168.98 @ Newegg Canada)
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard  ($169.98 @ NCIX)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($109.98 @ DirectCanada)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($92.98 @ NCIX)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($130.01 @ DirectCanada)
Total: $2004.85
Generated by PCPartPicker 2016-03-27 20:23 EDT-0400
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
Total: $2004.85
Thank you for this but i a may just start with 8gb of ram and the HDD, then later upgrade to ssd for boot up and 16 gb of ram later, i will be posting some part that i want and my design for my build later
So i made my list and i would love opinions and other ideas. My design theme is nuclear waste so green is will be the colour scheme.
Part list:
CPU: Intel core i5 6600K 3.5 ghz
CPU cooler: Noctua NH-L12 120mm & 92mm SSO Bearing PWM fans CPU Cooler
Motherboard: ASRock Z170 Pro4S LGA 1151 Intel 6gb/s USB 3.0 ATX
RAM: G.SKILL Ripjaws V series 8GB (2x 4GB) 288-pin DDR4
Storage: Western Digital Caviar Blue 1TB 3.5” 7200RPM internal hard drive
GPU: MSI GeForce GTX 970 Gaming 100ME
Power supply: some 600W modular PSU (thoughts on modular PSU?)
Case: Cooler Master N400 NSE-400 KKN2 N-Series Mid Tower Computer Case
Total: $2004.85
I am a huge fallout fan and i love green so any suggestions for my design for a more post apocalyptic feel? Also whats your opinion on my parts list
Part list:
With your budget you could actually build a pretty bitchin' pc.  Since this is your first pc though I'd recommend being a little conservative and save some money (no need to go with a hyper-threaded i7.  I'd only list an unlocked processor just for the ability to overclock later on down the line, wouldn't recommend trying it immediately considering you're new to pc's.)  You'd be perfectly fine running an i5, a nice air cooler, 8gb of ram, and a gpu around the 960-970 area.  Considering your budget you may as well go for a Boot SSD, especially since they've been dropping in price as of late.  Fully modular power supplies are always nice to go for since they help A LOT with cable management.  I also noticed you said that you're a fan of the fallout series and would like something to fit that theme so I picked out a Corsair C70 Vengeance in OD green, I had one for my first full-on build and it was pretty awesome, a little big and kind of expensive but still a very cool case nonetheless.
We've all started where you're at and learned from there, and this forum is pretty friendly so please don't be afraid to ask questions.  I do also recommend searching old forum posts, youtube videos, and guides, as many, many questions have already been answered and it's always a good idea to get a good knowledge base.
Motherboard: Gigabyte GA-Z170X-Gaming 5 ATX LGA1151 Motherboard  ($189.99 @ NCIX)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory  ($59.99 @ Canada Computers)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($116.98 @ DirectCanada)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($64.98 @ DirectCanada)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($424.99 @ NCIX)
Case: Corsair C70 Military Green (Green) ATX Mid Tower Case  ($159.98 @ NCIX)
Power Supply: EVGA SuperNOVA P2 650W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($104.99 @ NCIX)
Total: $1536.84
Generated by PCPartPicker 2016-03-30 23:24 EDT-0400
On 3/27/2016 at 4:52 PM, Northern_Lion said:
"Also i have a cousin who has a custom build PC and he says water cooling is the best."
Watercooling is generally better than air cooling, however it's only really necessary when overclocking, though depending on how much you OC there are plenty of air coolers that will suffice.
Quote
"Anyways i also don't know what to do i choose air cooling because of the ram clearance issues i have seen."
Depending on how big the Air cooler is and how tall the heat spreaders are on your ram you could potentially have clearance issues, though they normally just require you to shift the fan position, or in what order you install parts (i.e. ram first, then heatsink, then put the fans on).  As someone else said earlier you can get low profile ram that pretty much renders the issue null.  Big heat-spreaders on RAM serve nearly no purpose anyways.
