I'm well aware that increasing voltage increases the temperature of a CPU, but I'm more interested in what else it does. I see the term electromigration thrown around a lot, but I've never seen it explained. So how exactly does high voltage damage a CPU, aside from heat damage?
https://linustechtips.com/topic/572525-how-does-high-voltage-damage-a-cpu/
higher voltage means more electricity will be flowing through the chip which causes more heat
and heat degrades electronics
in case of extreme voltages - it just blows up the chip
also some people are concerned with electron migration but it's not really a thing... (you can look it up on wikipedia for what it means)
mainly it's too much power that outputs tremendous amounts of heat and blow the circuitry away if it's not cooled properly
also high enough voltage can blow capacitors and melt resistors away which also causes permanent failure
https://youtu.be/EoWMF3VkI6U?t=1m25s
https://youtu.be/Gw-rUCwLoQ0
https://youtu.be/JCPXckfT-6g
https://youtu.be/fyQVc2YVpX4
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
9 minutes ago, HighFlux said:
tbh its just the heat thats causing problems
thats why people can push to insane voltage on LN2 `-`
stability though is another story
-sigh- feeling like I'm being too negative lately
This is how I understand it (willing to be corrected of course, I am by no means an expert in microelectronics):  The transistors inside of a CPU are made up of what are called PN junctions.  The "N" meaning its doped with extra electrons, the "P" meaning that its doped with a lack of electrons, or holes.  A higher voltage across the PN junction causes the extra free electrons to recombine with the holes on the other side of the diode, which basically ruins the PN junction.
Some more reading: http://www.circuitstoday.com/pn-junction-breakdown-characteristics
2500k | Z68-UD3H-B3 | GTX 570 Classified + Accelero Xtreme III | MX 200 250GB + Seagate 500GB | R4 | Seasonic 660W Plattinum | 8GB G Skill | Acer K272HUL + 2 x Dell P2417H, Rosewill dual mount, HP 22bw | Mackie CR3, ATH-M50X | DAS Keyboard | Mobile: X1 Carbon, Nexus 6P, LG G3, Samsung S5, Nexus 7 (2013)
This is basically how it works, but unless you are trying to push 5V through the CPU then your CPU will be obsolete and replaced before any real damage occurs. Heat is much more damaging to the chip since it can ruine a chip within minutes.
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
