Hey,
I bought a Blue Snowball iCE and it arrived today, whilst testing it I have noticed that it picks up a lot of background noise and has a humming sound constantly.
Whereas my bad headset mic does not, any help to prevent/remove the background noise would be greatly appreciated.
Smiffy
https://linustechtips.com/topic/572021-blue-snowball-ice-issue/
11 minutes ago, Smiffy_ said:
Hey,
Smiffy
plus it directly into a usb 2.0 port on the back of your computer
one of the direct motherboard ones
https://linustechtips.com/topic/572021-blue-snowball-ice-issue/#findComment-7497779
Hello my friend! As for background noise, there's not a whole lot you can do because microphones like the Snowball, Yeti, AT2020, and most other higher end USB microphones pick up a lot of background noise as a rule. Turn the levels down through Windows and speak closer to it, I did that to reduce background noise and it worked fantastically. As for the humming, it might be fixed by merely putting some sort of soft padding under the tripod. I had a similar problem with the Blue Yeti, and I simply folded a t-shirt and set it under the stand; thus fixing my problem with the humming. Hope I helped!
https://linustechtips.com/topic/572021-blue-snowball-ice-issue/#findComment-7500071
