GPU doesn't use more then 20% power
Go to solution Solved by snorthd,
I just noticed my processor is running at 0.8 ghz!!!! What should I do to fix this?
I have a ASUS strix GTX 960 and for the past few weeks I have been getting fps way lower then normally no matter the setting. I get about 20 fps or lower in most games no matter how high or low the settings.
I have checked the smart data on my SSD and HDD. I have reseated my GPU and and checked my cables. I also made sure very thing was up to date but nothing seems to be helping.
Any ideas what might be causing my problems?
https://linustechtips.com/topic/571874-gpu-doesnt-use-more-then-20-power/
Use MSI Afterburner to see what is slowing down your system while in game.
Post a screenshot of the graphs (CPU and GPU usage and temp)
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
I have checked all my connections in my computer and they are how they should be.
I have been testing with a few games and it changes from game to game but no matter what I don't reach anything over 50% gpu usage and still have free RAM and CPU head room on each core.
Thought it might help if I let you guys know my PC specs.
-Intel Core i5-6500
-Asus STRIX GTX 960 2GB
-MSI Gaming B150 MOBO
-G.SKILL Ripjaws V Series 8GB (2 x 4GB)
-Antec 450W
-Intel 330 Series 60GB
-WD 1TB Black
-ASUS 1080p IPS monitor
