What Multi Bit Screwdriver does Linus use?
Go to solution Solved by W-L,
5 minutes ago, FrenchToast said:
-SNIP-
If you want the exact one linus has it's a snap on ratcheting multi-bit driver, others lower cost solutions out there will do a very similar job also:
https://store.snapon.com/Standard-Handle-Screwdriver-Ratcheting-Magnetic-Standard-Orange-8-3-4--P634146.aspx
Hi guys,
I was just wondering what screwdriver Linus uses? I'm planning on buying a multi bit screwdriver, and it seems that Linus's has served him well.
Any suggestions for other decent screwdrivers (with magnetic tip) would be appreciated, too. Thanks lads!
https://linustechtips.com/topic/571731-what-multi-bit-screwdriver-does-linus-use/
you could try this....not a personal recommendation as I have never used it, but seems to have good reviews on Amazon:
http://www.amazon.co.uk/Bahco-808050-Ratchet-Screwdriver-Bits/dp/B001DZI2VK/ref=sr_1_fkmr0_3?ie=UTF8&qid=1458975586&sr=8-3-fkmr0&keywords=Orange+ratcheting+magnetic+screwdriver
CPU:                Intel Core i7-6700K 4.0GHz (Skylake) Socket LGA1151 Processor
Graphics:         Inno3D GeForce GTX 980Ti Hybrid Black Edition 6144MB GDDR5 PCI-E
RAM:              Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz
Case:                Phanteks Enthoo Evolv ATX Mid Tower Case - Black (3x 140mm Phantek fans)
MOBO:            Asus Maximus VIII Hero Intel Z170 (Socket 1151) DDR4 ATX Motherboard
Boot SSD:        Samsung 250GB 840 EVO SSD 2.5" SATA
Game SSD:      Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive
CPU Cooling:  Overclockers UK & SilverStone - 120mm FQ121WC Watercooling Radiator Fan x 2
                       Asetek 240mm 570LX
PSU:               Corsair 750M Semi-Modular 80 Plus Gold rated
Monitor 1:       Sony BRAVIA KDL32W705BBU Smart 32" LED TV
Monitor 2:       Samsung 24" S24C300
Keyboard:        Razer Blackwidow Chroma
Mouse:             Roccat TYON
Speakers:         SBS2112 with Bluetooth
Headset:           Turtle Beach Elite 800 Stealth
Looks pretty good, thanks for your help :)
-SNIP-
Found a link to the Oz store which may be a bit more helpful as only just realised your not in the UK O.o
http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=634146&group_ID=675083&store=australia&dir=catalog
Only $143.09.... sure if you find a hardware store around you then you can find it cheaper...well at least I hope o.O
Just tried that link with a UK version of the store and the price is a bit more on the realistic side at £63.96
http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=634146&group_ID=675083&store=uk&dir=catalog
Sure if you use your normal local shopping outlets you will find it cheaper as over 50 bucks for a screwdriver is a little bit killer if you ask me, although as they say, buy cheap, buy twice....
                       Asetek 240mm 570LX
Mouse:             Roccat TYON
Moved to Off Topic.
Sweet, thanks for that mate
I have the 123-PC. 1/4" Hex Drive Mac-Grip Ratcheting Bit Driver Set. It's better value than the Snap-On because it includes pretty much any bit you could ever want. Mac Tools is another very trusted company among professional mechanics and techs.
