so this is my first pc build gonna make the box my self but im on a budget of $1000 nzd give or take $200
i need advice on whats the best way and place to get good parts cheep im not looking at vr on any thing 10/10 but skyrim on high with a few mods would be what im aiming for
and i do live in New Zealand :D
Thanks in advance
https://linustechtips.com/topic/571178-help-build-a-pc/
This is what I'd get for $1200 NZD. I've added a SSD so you can save money there if you take it out but it does make a world of difference if you use it as a boot drive.
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($299.00 @ PC Force)
Motherboard: ASRock H110M-DGS Micro ATX LGA1151 Motherboard  ($88.55 @ PB Technologies)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory  ($54.78 @ PB Technologies)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive  ($74.64 @ Aquila Technology)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($82.80 @ PB Technologies)
Video Card: Sapphire Radeon R9 380 4GB NITRO Dual-X OC Video Card  ($355.35 @ PB Technologies)
Case: Silverstone PS08B (Black) MicroATX Mid Tower Case  ($70.74 @ Ascent Technology)
Power Supply: Corsair CSM 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($138.00 @ 1stWave Technologies)
Total: $1163.86
Generated by PCPartPicker 2016-03-25 21:58 NZDT+1300
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/571178-help-build-a-pc/#findComment-7490303
1 minute ago, SARGTEAPOT said:
Thanks looks great do you know if the mother board has 2 storage slots?
I'm not sure if I know what you're talking about. Do you mean memory slots?
https://linustechtips.com/topic/571178-help-build-a-pc/#findComment-7490333
what im looking at wont be getting a case as im building one my self
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($379.95 @ Computer Lounge)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($63.00 @ 1stWave Technologies)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  ($68.50 @ 1stWave Technologies)
Power Supply: Corsair VS 550W ATX Power Supply  ($89.00 @ 1stWave Technologies)
Total: $1181.93
https://linustechtips.com/topic/571178-help-build-a-pc/#findComment-7490348
5 minutes ago, SARGTEAPOT said:
storage as in hard drives ssd
That's gonna be more a case issue than a motherboard issue. As far as I know, all modern motherboards will come with three or more SATA headers. The case will accept one 2.5" (so an SSD) and three or four 3.5" (so hard drives, although you most likely can adapt down to 2.5" there). Should be no problem ;)
EDIT:
started writing before your reply. If you build enough bays for the drives, that's no problem (sounds cool, what are you planning to do?). Anyway, the mobo you picked supports four drives.
https://linustechtips.com/topic/571178-help-build-a-pc/#findComment-7490353
Total: $1181.93
Three gripes:
-Firstly, you can't overclock on that motherboard. You'll need the more expensive Z170 to do so, so getting the i5 6600K is just wasting money. The i5 6600 is your best choice.
-The SSD is very mediocre. The A-data SP550 and the Sandisk SSD PLUS are much better choices.
-The PSU is crap in terms of quality. I recommend sticking with the CS550M I suggested as the bare minimum.
https://linustechtips.com/topic/571178-help-build-a-pc/#findComment-7490364
CPU Cooler: Deepcool GAMMAXX 300 55.5 CFM CPU Cooler  ($37.05 @ PC Force)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  ($75.27 @ Aquila Technology)
Storage: Seagate  1TB 3.5" 7200RPM Hybrid Internal Hard Drive  ($113.85 @ PB Technologies)
Video Card: Asus GeForce GTX 960 4GB Video Card  ($378.35 @ PB Technologies)
Case: Deepcool TESSERACT SW ATX Mid Tower Case  ($86.63 @ Wiseguys)
Power Supply: Zalman 400W ATX Power Supply  ($43.70 @ PB Technologies)
Total: $1203.35
Generated by PCPartPicker 2016-03-25 22:21 NZDT+1300
1200$
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/571178-help-build-a-pc/#findComment-7490373
Total: $1203.35
1200$
The chipset does not allow overclocking, so one could save twenty bucks there. And the 380 performs (if only slightly) better than the 960 and is thirty bucks less, so then one could use those $50 to get a better PSU (never really heard of Zalman, so I may be wrong) and/or an SSD, especially considering OP doesn't need a case.
https://linustechtips.com/topic/571178-help-build-a-pc/#findComment-7490384
It is not 30 bucks less. It is 20 bucks more, but pcpartpicker makes it around 100 bucks more, so no. And Zalman isn't used too much, but well, it was just on of the cheapest. And a Hybrid is much closer to a SSD than a HDD. I didn't know it couldn't overclock the CPU, but i knew i t could obviously overclock the RAM (It's not just Z170.)
https://linustechtips.com/topic/571178-help-build-a-pc/#findComment-7490392
Just a heads up alot of these retailers have Easter sales atm so have a check through the pricing as it may be 5-10% cheaper(I see your not purchasing now so keep an eye on the sales, sign up to the newsletter things) and I'd suggest getting everything from one place as RMAing things could become he said she said between the retailers. Not to mention couriering for RMA's
Just speaking from experience
CPU: Intel i7-4790K @ stock for now --- RAM: Corsair Vengeance 16Gb --- MOBO: Asus Maximus VII Formula --- GPU: MSI Gaming GTX 980ti --- PSU: Corsair AX860i  ---  Storage: Samsung 850 250gb(OS), 3x Western Digital Blue 3tb (one for game and programs, two for media), 3tb WD Green(somewhat backup) and a Crucial M550 120gb SSD (caching games and programs drive)  --- Case: Fractal Define R5 --- Cooler: Corsair H100i with Noctua 2000rpm, Industrial Fans --- OS: Windows 10 --- Monitor: Asus PB298q + AOC l2260SWD --- Mouse: Logitech G502 Spectrum --- Keyboard: Corsair K70 (Cherry MX Red) Red LED's --- Audio: Audio Engine A2's (yes the originals), Sennheiser HD 58x Jubilee Audio-Technica ATH-AD900x, Audio-Technica ATH-M50x, Ant Lion Mod Mic V4 --- Laptop: Dell XPS 9750
https://linustechtips.com/topic/571178-help-build-a-pc/#findComment-7490393
But... OP can buy it from the same retailer for 355 (so 20 not 30, don't know why I goofed there) instead of 378. Am I not seeing something there?
As for the PSU, I can't seem to find anything about that unit, so I really can't comment much on it.
https://linustechtips.com/topic/571178-help-build-a-pc/#findComment-7490401
