This is my first pc build! Tell me what you think! (Some parts will change)
CPU: AMD FX-4350
GPU: GeForce Gt 730 (Will change)
RAM: Kingston HyperX Fury 16 GB Memory
MOBO: ASUS M5A97 LE R2.0
Case: Corsair Carbide SPEC-02
PSU- Raidmax RX-500 XT
Storage: WD Blue 1TB
CPU Cooler: Cooler Master Hyper 212 Evo
Red (Soon to be Retired)CPU: FX-8350 Cooler: CM 212 Evo  GPU: Gigabyte GTX 1060 6GB RAM: 16 GB Kingston HyperX 1866MHz Mobo: Asus M5A97 LE R2.0 SSD: Kingston 128 GB (Boot), Samsung 860 EVO 500 GB (Main Games) HDD: WD Black 1 TB (Storage + Older Games) PSU: EVGA W1 500W Monitor: Dell ST2220l 21.5". Peripherals: Razer Blackwidow Ultimate 2013 Keyboard, Razer Deathadder Mouse, SteelSeries mosepad,
https://linustechtips.com/topic/570994-red-pc-build/
CPU: AMD FX-4350
What´s your overall budget and location?
https://linustechtips.com/topic/570994-red-pc-build/#findComment-7488595
Budget: $500
USA
https://linustechtips.com/topic/570994-red-pc-build/#findComment-7488596
Just now, ShadowTechXTS said:
That thing will catch your house on fire.
Is it that bad?
https://linustechtips.com/topic/570994-red-pc-build/#findComment-7488604
Just now, SATANGOD666 said:
Does this budget include OS and a monitor?
yes and no
OS: windows 10 (included in budget)
Display was just an old dell 1080p monitor that i have been using for a while now with no problems
https://linustechtips.com/topic/570994-red-pc-build/#findComment-7488611
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($204.99 @ Newegg)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($44.99 @ Micro Center)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory  ($35.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.88 @ OutletPC)
Video Card: Sapphire Radeon R9 380 4GB NITRO Dual-X OC Video Card  ($159.99 @ Newegg)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  ($37.99 @ Micro Center)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($61.98 @ Newegg)
Total: $584.81
Generated by PCPartPicker 2016-03-24 19:18 EDT-0400
i guess you can go lower with a i3 6100
get win 10 key from r/microsoftswap or kinguin for cheaper
https://linustechtips.com/topic/570994-red-pc-build/#findComment-7488612
Total: $584.81
That´s $100 over budget dude.
https://linustechtips.com/topic/570994-red-pc-build/#findComment-7488617
what is a good graphics upgrade i could get within the budget that i could change maybe?
https://linustechtips.com/topic/570994-red-pc-build/#findComment-7488631
Just now, Aytex said:
is your budget $500 USD  EXACT or can you go a little higher
i could go a little higher
https://linustechtips.com/topic/570994-red-pc-build/#findComment-7488644
This is a pretty decent build for your budget http://pcpartpicker.com/p/svsNXL you cant get windows of Kingun.com for around 30 dollars. Just have to have another computer to download windows onto, so you can put it into a bootable usb and boot your computer. Or you could get Ubuntu Linux if wanted.
https://linustechtips.com/topic/570994-red-pc-build/#findComment-7488646
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  ($122.88 @ OutletPC)
Motherboard: MSI H81M-E34 Micro ATX LGA1150 Motherboard  ($40.99 @ NCIX US)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($37.89 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($45.89 @ OutletPC)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($43.56 @ Mac Mall)
Total: $481.19
Generated by PCPartPicker 2016-03-24 19:25 EDT-0400
https://linustechtips.com/topic/570994-red-pc-build/#findComment-7488649
Total: $481.19
Very good.. You could then go to Kingun.com and get windows for around $30 dollars. So it would only be around $10 over the budget.
https://linustechtips.com/topic/570994-red-pc-build/#findComment-7488658
