Kraken X61!!!  Super easy to install and the drivers are decent. Keeps my 4790k around 60c on 100% load!
Current Build: Core i7 4790k @ 4.6, Asus Maximus VII Hero, Corsair Vengeance Pro 2400mhz 8gb (2x4gb), GTX 980ti, NZXT Kraken X61, Fractal Define R5  EVGA Supernova B2 850w, Some 300gb hard drive.
http://pcpartpicker.com/p/W7CNrH
https://linustechtips.com/topic/569769-water-cooling/#findComment-7476366
Personally, I'd be inclined to get the EK Predator 240 or 360. They are both good coolers that can be expanded into a full loop in the future if you want. I may be biased here, but the ability for a full loop... MUST HAVE.
¢υѕтσм ℓσσρ σя ησтнιηg αт αℓℓ
https://linustechtips.com/topic/569769-water-cooling/#findComment-7476367
x61 or H110iGTX
https://linustechtips.com/topic/569769-water-cooling/#findComment-7476389
Depends on what size rad you can use :
120mm = h80i
140mm = CM nepton 140XL
240mm = h100i
280mm = kraken x61 or h110i
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/569769-water-cooling/#findComment-7476405
