Hi everyone!
My fans are shipping to me as we speak and i don't know whether i should buy the NZXT Sentry 3 fan controller or not. It's like 50€ and if its not worth it i obviously don't want to spend it. So long story short should i honestly buy it or use software for controlling the fans?
Thanks in advance!
https://linustechtips.com/topic/569381-bay-fan-controller-worth-it/
If you have to constantly adjust the fan speeds, a controller is really nice. Otherwise I wouldn't bother.
You can of course build the PC and use it for a while, then decide if you need the physical controller.
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
I've never had a problem just letting the software control the fans depending on temp myself, but I don't game.
I had a fan controller, but TBH even when using a lot of CPU load it was just a pain to be fiddling with the fan controller.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
Manual fan control is pointless and annoying when there are other automatic options out there.
If your new fans aren't PWM fans, then something I'd recommend is the NZXT Grid+. Allows almost pwm-like control on 3pin fans using NZXT's 'CAM' software. It's kinda clunky in the menus, but once it's configured you can leave it alone. You can have individual fans ramp up or down dependant on CPU or GPU Temps and even turn off if not needed. I have my front two fans ramp up or down along with the temps of my GPU, the rear fan running alongside CPU temperatures and my top two fans only turn on when the CPU is over 50 degrees. Although you do need some room for the physical unit itself, I don't really see the need for manual fan control anymore.
But to directly answer your question: No, a front bay manual fan controller isn't really worth it... IMO of course
EVE (My Gaming Build)
Motherboard: Asus Maximus VII Ranger - CPU: Intel i5 4690k @ Stock Speeds - Cooling: Phanteks TC-12DX - PSU: Corsair RM750 - GPU: MSI GTX 1070 - Storage: 1x 120gb Samsung 830 Evo SSD (OS Drive) | 1x 120gb Hyperx 3k SSD (Audio Editing) | 1x 480gb Sandisk Ultra II SSD (Games) | 1x 1TB Hard Drive (Mass Storage) - Case: NZXT Phantom 530 - Misc: NZXT Hue RGB LED and controller
